Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-12-2009, 07:12 AM
nascar88ford nascar88ford is offline
1987 Ford F-150
My Garage
nascar88ford is starting off with a positive reputation.
Now that's awesome. I always liked that feature, and never had it!
For the mileage, it's actually lower that what it truly has. That why I went ahead and installed it, so it wouldn't be even more off. I can live without the door ajar light and cab light for now, until I go by a dealer.
__________________
2005 F-150 STX Reg. Cab 4x4 4.6 Silver
1987 F-150 Reg. Cab 4.9 Auto Red 250,000
  #17 (permalink)
Old 08-05-2009, 04:36 PM
1987 Ford F-150
My Garage
I finally went by the dealer. At first, the guy was like "It can't be done, it's not and FX4." After 30 minutes I went into the service area and asked what he was doing. He was under "Instrument Cluster Programming" which is NOT what you need. Whichever scan tool he had was different. You have to go under the third opinion on the main screen. He went in, filled out the "As-build" data and click! Everything was normal. All dings, alerts (low fuel) and lights worked, as well as the -- and ---F turned off. It is just like I had. They look awesome!
Thank you for all of your help! If anyone has any questions, let me know!
-Matt
__________________
  #18 (permalink)
Old 11-07-2009, 06:46 AM
jhrsmail jhrsmail is offline
jhrsmail is starting off with a positive reputation.
Smile
Great post/info.
I am at that point myself with my STX. Changed the cluster to FX4 and took it to the dealer. They said they would try it for 85 dollars without garantee. Kinda made me nervous. Next I will tell them to send "As-built" data to cluster. This post has helped.
About the compass wiring: I attempted to install this also, but have been unsuccessful. The compass (4 pin) wiring routes to the passenger side above the fuse panel. There is a connector to send these wires to under the hood. PINs are:
Pin 1 White/orange strip (compass data +)
Pin 2 White/Black Strip (compass data -)
Pin 3 White/lite blue strip ( 12 Voltages supplied in Start and Run mode)
Pin 4 Black/lite blue strip ( ground)
Mirror wiring routed to drivers side (6 pin):
Pin 1 White/lite blue strip (12 volts at start/Run)
Pin 2 Black (ground)
Pin 3 Black/Pink strip (Trailer Tow Relay Reversing lamp switched power)
hope this helps someone
Tags
05 , 1999 , 2004 , 2007 , changing , cluster , expedition , f150 , ford , fx4 , gauge , instrument , mileage , swap , truck , xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
