How to tell if ball joints are bad?
I have an '02 4X4 crewcab V-10. I had the tires replaced recently and the tire shop said the ball joints on the left side were worn. Wanted mucho dollars to replace. Ford dealer said they are worn on both sides, but not "badly" worn. Neither would tell me exactly how they know this.
What can I do in my driveway to tell if the ball joints are indeed worn, and how worn is too worn?
No other front end work has been done (104,000 miles now) except for replacing the "links" a couple years ago. Should I consider any other bits and pieces while I have things torn apart?
on
Have somebody put a bar or 2x4 under the wheel after it is jacked up while you watch for movement at the joints. Does it pull when you hit the brakes? Tire wear on the inside? Make creaking, squeeking, or clacking noises? If it has over 100k miles they are probably worn out. You can save money by doing it yourself. Be prepared to work...........Posts in here.
All of my balljoints --- I changed them out one side, then the other side --- failed in the 60K -70K mileage range. Stock suspension.
Unless you see wear in the axle u-joints, there really isn't much else to change while you are in there. There are even little kits that our sponsors sell (I don't know anything about them). The balljoints, axle dust seas, knuckle seals, o/rings, and I go ahead and change the needle bearings in the hub assy since they are so cheap.
Good luck.
on
The U-joints are usually good unless they spent a lot of time under water because they get very little action compared to the ones on the rear driveshaft. I wouldn't attempt to change the needle bearings unless they need it. (Too many stories about screwing them up and causing them to fail by changing).
I remember someone here recently stating he didn't understand the bearing, because he had a *cageless* bearing with hardly anything holding the rollers in place.
They pop in and out. No?
on
on
People have been changing them since RacerGuy wrote his guide, like 5 years ago, since they are I remember someone here recently stating he didn't understand the bearing, because he had a *cageless* bearing with hardly anything holding the rollers in place.
Here's a link to the ball joint section of our site.If you have any questions,I'd be glad to answer them for you.
Ford Truck Ball Joint
I had my truck at the dealer getting other warranty work done, and it had a slight pull.Told them to check the ball joints. They told me they were fine just needed an alignment. Since my crew cab wont fit on my alignment lift I told them to go ahead and do it. Still pulled when I got it back so I checked them myself, left side was shot and right side was not too great. This was with 33K miles on the clock. My point, trust noone when checking them but your own eyes. Replaced them with MOOG and got new seals from ford, been great so far.
