Stout 460 Motor mounts
Cause not from what I've seen solid and solid is fine. But there is always a connection from the block/bellhousing junction to the roll cage.
I've always heard/seen that mixing and matching is bad.
Delrin Motor mounts and poly trans mount seem to be ok though...
uhh? You sure? What about when a motor plate is involved?
As for the chain limiter - there are multiple ways to do it. The point is - IF the motor monuts break - you don't want the engine moving/flopping around under the hood due to the torque/roll created when you get on the gas - or in cases like what I do - when you hit a jump or set of whoops. Ask me how I had my hood dented upward from underneath in the 1st truck I ever owned
Anyways - the chain should go from the block/motor mount bracket on block to the frame/motor mount bracket on frame or around the motor mount. It should be pretty common sense to figure out based on my description of what you are trying to avoid above
firstrider
04-02-2017 07:49 PM
Dieseladdicted
40
01-19-2017 04:55 PM
william16339
10-24-2016 02:37 PM
