Hissing sound from Brake pedal
I did a search and came up with nothing. Maybe I was searching wrong..Anyway my wifey's 2003 Expedition is giving me problems. I thought I had fixed it before but there is a hissing noise that is coming from the inside of the cabin area down by the brake pedal/booster area. Before I noticed a small rubber boot that looked like it came off the brake pedal rod, so I put it back in place. The hissing sound went away..wife was happy for a few days than she told me it was back....is this boot a common problem? The hissing seems to be a vaccum leak since when you depress the pedal the sound goes away until you release the pedal.
Any thoughts?
Any thoughts?
Brake Booster Bad
Your vacuum brake booster has a bad seal and needs to be replaced. They sell remanufactured ones so its not too expensive. To confirm diagnosis, with vehicle running and in Park, open hood and remove vacuum line from the brake booster. If that eliminates the hissing inside the cabin, you need a new brake booster. The seals are not serviceable.
1986stepsidef150
07-22-2012 09:45 PM
ronjeremy6
1997-2006 Expedition & Navigator
07-24-2009 07:23 PM
pitakit
Escape & Escape Hybrid
09-05-2002 03:09 AM
