Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-07-2009, 05:47 AM
jhkfarms jhkfarms is offline
jhkfarms is starting off with a positive reputation.
Fuel system problem
I have a 1997 F-250 7.3 liter turbo diesel with 225,000 miles. When diesel prices got so high, I did not drive it to much. Meaning it would set for weeks before being driven. When I started driving it more often, it was hard to start, would die almost immediately after it started. I would have to hold the gas pedal done to get it to stay running after it started. The other day I was driving it, when it started jerking, no acceleration, then died. When I removed the fuel filter lid, I could see black specs floating in the fuel, the filter appeared completely blocked. I drained the old fuel out of the bowel, replaced the fuel filter, maybe drove 30 miles, before it quit running again. Once again black specs in the fuel and the filter was plugged. Do I have bad fuel lines that need replacing? If I did, has my fuel pump been damaged.
Thanks, Hoby
  #2 (permalink)
Old 10-29-2009, 06:51 PM
RE: Fixed
Just wanted to once again thank those that attempted to help me. I ended up taking my pickup into a diesel shop. It had a lot wrong with it. The IDM was bad, I had a burnt glow plug connector, They put a new upgraded turbo boot, she now runs better than new. I didn't run it to the dealer, I took it to a local diesel shop. It seems the fuel was not the real problem.
Thanks, Hoby
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
