how long with bad clutch packs
2004 F150 FX4 97K
When acclerating and turning from a stop
(like making a left hand turn), the rear end kind of stutters
and then hops/bumps and goes smooth. One wheel
turning faster than the other? Researching this site it
sounds like the bad clutch packs TSB. Question:
how long can I drive with this problem before I mess
something else up seriously on the truck? My ford dealer
quotes $1200 for the repair, and I would like
to postpone the expense.
If fords quoting you 1200 bucks for just new clutch packs thats rediculous...
The rebuilding of the limited slip is about 200 bucks at best at a mechanic, now if you have other problems in the rear end, thats a different story.
You should be able to have a new (not rebuilt), much better limited slip (an eaton or tru trac) installed for about 600-700 bucks
I'd ask what parts they're replacing, at the 1200 bucks they're quoting you i'm wondering if they're rebuilding with new bearings, gears, and axles....which probably aren't needed.....
I would try changing the rear end oil and add new friction modifier to see if that helps out any. You won't break anything by doing this. If the shudder goes away you're home free. If it still shudders, then you may need a new clutch pack. You should be able to have an independent shop rebuild the clutch packs for in the $500-$600 range parts and labor.
Would Ford tell me?
Edit--here is the TSB, and they are saying to use 75W-140 rear end lube even though 75W-90 may have been the original recommendation https://www.ford-trucks.com/tsb/full...php?tsb=06-4-4
For the F-150, Ford says that you only replace the clutch packs and that it takes 3.2 hours of labor. Sounds like less than $500 to me.
Chattering clutches in the rear axle are not really a major problem, although they can be annoying. All this means is that the limited slip unit is trying to grab; I don't think it's gonna hurt anything else unless you're running lots of torque thru the rear axle.
Still, with the mileage you've got, it would be a good time to drain the rear axle and replace the lube...there is bound to be some work friction material floating in the lube.
Before you spend big bucks on the unit, go to an axle shop and have them replace your factory limited slip with something like an Eaton posi unit--I have an Eaton posi in my 2002 E150 van and it works great....and by the way, my Eaton unit has chattered a bit since it was new in situations like you describe (tight turn on wet pavement with a little kick to the throttle).
George
but for clutch packs you don't even need to pull the axles all the way out if you don't want to....its no where near 1200 bucks
maybe the local stealership was wanting to overcharge ford or somthing...because thats the same axle on my truck as when i bought it
