Standard Tires on an F250 FX4? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-06-2009, 01:39 AM
jrandol jrandol is offline
jrandol is starting off with a positive reputation.
I have an 05' F250 Crew Cab 4wd w/ the FX4 package (has V10 motor) with about 53k miles on it. The prior (and original) owner replaced the OEM BF Goodrich tires on it for Firestones! The Firestones are about shot and must go. Current tire size on it is 285/75 R 17 (stock wheels) and I just kind of assumed he replaced the tires with stock size. Well the door panel says 265/75 R 17 is standard. Which is right??
If 265's are the standard size, will I see any noticeable improvements in power/accelaration going back to a smaller diameter tire? My truck is an Auto w/ the 4.10 gears.
BTW, I'm pretty dead set on Michelin LTX tires as I've had great luck with them in the past. However, I'll listen to suggestions! Truck sees little off road use, but Colorado winter roads often. About 85% on pavement highway or town driving.
Old 07-06-2009, 06:05 PM
07250psd's Avatar
07250psd 07250psd is offline
07250psd is starting off with a positive reputation.
Yes, the 265/70/17 were correct factory size. They are about 31 inches tall and the 285/75 are about 33 inches tall. I'm not sure if you would notice a difference but your speedo might be more accurate with original tires, if it was not recal'd. Just make sure the new tires you get are Load Range E. This is a debate (D or E) I suggest range E.
Old 07-06-2009, 06:08 PM
Quote:
Originally Posted by 07250psd View Post
Yes, the 265/75/17 were correct factory size. Just make sure the new tires you get are Load Range E. This is a debate (D or E) I suggest range E.
Thanks 07! Yep, Load Range E without a doubt.
Old 07-06-2009, 06:19 PM
Ace!'s Avatar
Ace! Ace! is offline
Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.
Mine came with 265/70/17E Pirelli Scorpions as stock, not BFGs, not that it makes a difference I guess.
Old 07-06-2009, 06:48 PM
Damon_Tirerack's Avatar
Damon_Tirerack Damon_Tirerack is offline
PLATINUM SPONSOR
Damon_Tirerack is starting off with a positive reputation.
You should use 10 ply tires. It's awfully heavy, and if you combine that with a load the tires won't be able to hold up to it without the added reinforcement.
__________________
Representing The Tire Rack
877-522-8473 Ext. 643
574-287-2345 Ext. 643
574-236-7707 fax
**Don't forget to add my name to online orders when checking out!**
87 f250 4x4 with 265/75r16 ? melvinew2 1987 - 1996 F150 & Larger F-Series Trucks 2 06-16-2016 03:01 PM
Looking for tires for my F250, mostly used to haul a boat in Florida grey2112 1999 to 2016 Super Duty 15 03-08-2016 08:14 PM
02 F-250 Utility bed 4X4 new tires 02f-2504X4 1999 to 2016 Super Duty 1 03-05-2015 11:02 AM
Tires and TPS PAf250 1997-2006 Expedition & Navigator 8 09-19-2011 06:57 AM
2005 F250 FX4 biggest tires w/no rub Larman237 Brakes, Steering, Suspension, Tires, & Wheels 4 01-17-2007 09:49 PM
Tags
17, 265, 70, duty, f250, factory, ford, fx4, load, pirelli, range, scorpions, standard, stock, super, tires, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
