Spark at "Run"...no spark at "Start"
1977 Ford F250 , 460 auto, stock DuraSpark II ignition.
I don't seem to be getting any spark when I turn the key to "Start". If I time it just right, when I release the key to the "Run" position, it will catch and run fine. Other times it'll kick back and try to run backwards. I've disconnected the coil wire and held it next to a good ground, cranked it over to "Start", and no spark, but just as the key goes from "Start" to "Run", there's a couple of sparks. I've never run into this problem before. It's got me stumped. Any ideas out there?
Thanks in advance....
Oh, I've replaced the ignition switch and no change. I get the same problem when I "hot wire" it and jump the solenoid under the hood.
If there is a second small post on the start solenoid (toward the rear) then that would be the power for the hot start for the ignition.
Bear....just tested and there's lots of juice at the "I" terminal on the solenoid. The test light gets really bright when cranking. I also checked all the wires from the 2 plugs at the ignition module on the fender apron to the coil/distributor, and all check out fine. Looking more and more like I need a new module. While I had the module off the truck, I cleaned the mounting areas, in case the module needed to be grounded. There's a "Standard Auto Parts" one there now, so it's been replaced once (at least) already.
Bear....just tested and there's lots of juice at the "I" terminal on the solenoid. The test light gets really bright when cranking. I also checked all the wires from the 2 plugs at the ignition module on the fender apron, and all check out fine. Looking more and more like I need a new module. There's a "Standard Auto Parts" one there now, so it's been replaced once (at least) already.
Last time I test one was 20 years ago and my memory isn't that good any more. I would have to dig out a manual and check to find out.
