engine tick
You probably have a bad cam phaser. It's the left or right side cam gear. Try to see if you can tell which side it's coming from. Also to verify, power brake the truck in drive, hold it at 1000 RPM. The noise then will be much more pronounced....should sound more like a knocking.
dealership spoke with ford today and ford wants an oil pressure test performed on it. apparently if ther is under 25psi of oil pressure the vct will not function properly
I have a knocking noise around 1000rpms when engine is hot. After taking it to the dealer, their "pro" said it was fuel injector noise which is normal. I have a hard time believing that one since it is noisier when hot only around 1000 rpms and with slight load on engine, not to mention my old 04 had the same rattling noise too. The cam phasers and tensioners were replaced in the old one and the noise went away for 20,000 miles but came back and eventually got worse. I noticed the noise around 3,000 miles. The oil was changed by the dealer at 5600 miles. It is more of a rattle sound, not a tick like an injector. I thought I was going to have a quiet engine when I said good writtens to the 04, but surprise, de-ja-vu. anyone else have the noise?
Guy, find out the lemon law in Ontario. Usually, after 2 attempts at repairing the same defect, you must give written notice to Ford for their final and last attempt to repair the defect to start the lemon law provisions. I strongly suggest you review the lemon law requirements and take the appropriate action.
Best of luck.
Best of luck.
Best of luck.
Best of luck.
