Bleeding power steering? - Ford Truck Enthusiasts Forums
Old 07-05-2009, 09:31 PM
Tim_in_MD Tim_in_MD is offline
Tim_in_MD is starting off with a positive reputation.
Hi,
The truck is a 1986 F250 4x4 with the 300 six and a 4-speed.
My PS cooler line sprung a leak so I fixed that but now I've got no PS at all. I had power assist when I started to bleed (wheels up, steering lock to lock). I was parking when the line went and I lost assistance, so the pump wasn't run dry.
Have I missed a detail of the bleeding sequence or did my pump coincidentally go up at the same time?
Plenty of fluid, belt is fine, no noises...just no assist.
Thanks!
Tim
Old 07-05-2009, 10:02 PM
Homemade's Avatar
Homemade Homemade is offline
Homemade is starting off with a positive reputation.
Im interested in this also as I have a power steering hose I need to replace soon.
Old 07-05-2009, 11:21 PM
Big Ben's Avatar
Big Ben Big Ben is offline
Big Ben is starting off with a positive reputation.
The way I have always done it is to pop the cap, start the vehicle and turn lock to lock for awhile, sometimes it can take awhile.
Old 07-05-2009, 11:43 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
There is no bleeding the power steering...
It's an open ended circuit thus will bleed itself with a couple lock to lock turns.
-Enjoy
fh <font color="#FF0000">:</font> )_~
Old 07-05-2009, 11:57 PM
ozstang65's Avatar
ozstang65 ozstang65 is offline
ozstang65 is starting off with a positive reputation.
I had a similar problem with my p/s after both box and pump were rebuilt. Long story short, it turns out that the shaft in the pump is disengaging from the pump rotor. The whole shaft and pulley work its way forewards until it disengages - then no ps, push it back in and it works. I assume some bonehead left the c-clip off the end of the shaft where it goes thru the rotor when it was being put back together.
Might be your problem, might not....
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I have never had one stop completely. Usually they are just noisy and the oil is all foamy when they have air in them, but they still work. Getting all the air out is a problem with Fords, and I believe the dealers had a vacuum device they fit over the reservoir to try to get it all out. But like I said, that's just to reduce the pump noise, otherwise they still work.
Take the line off the steering box and also the belt off the pump, and see if when you turn the pulley by hand, you get oil out of the pressure line.
Old 07-06-2009, 12:00 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Jack the front tires off the ground and push/pull a wheel back ane forth slowly, stop to stop without the engine running.
Old 07-06-2009, 01:27 AM
Methanoholic
Quote:
Thats ludicrous, there is no way to vacuum off aeration.
If your powersteering is aerating the fluid there is a problem with the pump and no bleeding or vacuum is going to solve it.
It's an open ended system and as long as the pump is not re-introducing air the solid stream of fluid will push the air through the system into the reservoir.
-Enjoy
Old 07-06-2009, 02:21 PM
Methanoholic
Franklin,
Just so it's clear, I am not dissing you on this, I am dissing the notion that a open ended hydraulic system needs to be bled.
-Enjoy
fh : )_~
Old 07-08-2009, 10:48 AM
Well thanks all. Sounds like I haven't missed anything. Guess the pump went up at the same time.
I did splice a hose over the bad section of the hard cooler line (since nobody carries this piece) but I can't imagine that would cause a problem since there's already flexible hose in the return line.
Old 07-09-2009, 07:24 AM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
hey Tim in MD I see your from the great state I'm in stop by the maryland chapter some time-we would love to have ya it's under forums then chapters-see ya there
power steering issue Ted928 2004 - 2008 F150 2 10-29-2016 10:47 AM
Bled my power steering without motor running. Uni Moe 1967 - 1972 F-100 & Larger F-Series Trucks 7 01-23-2015 12:34 PM
91 F350 7.5 power steering is out. JoeJJones 1987 - 1996 F150 & Larger F-Series Trucks 33 08-30-2014 08:44 PM
Power Steering Problems, 1974 F100 InGear 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-20-2013 12:59 AM
Power steering pump install/bleeding system Myfreeford 1973 - 1979 F-100 & Larger F-Series Trucks 11 11-23-2012 03:34 PM
Tags
250, 77, 78, aeriating, bleed, bleedeng, bleeding, dealer, diecel, f250, fluid, ford, power, pump, steering, troubleshooting, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
