Alternator wiring - Ford Truck Enthusiasts Forums
Alternator wiring
Old 07-05-2009, 06:04 PM
polarisman729's Avatar
polarisman729 polarisman729 is offline
polarisman729 is starting off with a positive reputation.
Exclamation Alternator wiring
Hey, I was looking into the wiring from my alternator and found it's all cobbed up. Does anyone have a wiring diagram for the alt on the 6.9 engine?? There are three wires comming off mine and there were about three more connected to the main one off the alt. Where are they going?? the voltage regulator is external. What are the wire on that for? Any info will help. Thanks.
Old 07-05-2009, 11:18 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Here's a little bit later model diesel, but I believe it's the same.
http://www.autozone.com/autozone/rep...20and%20Bronco
Old 07-06-2009, 02:02 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
That diagram Franklin posted will only work if you have a truck with Warning lamps instead of Gauges.
The routing of the altenator wiring for a truck with gauges is different.
Old 07-06-2009, 06:47 PM
Well I took the alt to autozone and had it tested. It tested fine. Came home and threw it back in and drove down there. Not charging. I don't get it. I went over the wiring from the alt and it all looks good. What am I missing??? The power line off the alt should go back to the starter relay right?? Does the alt need a ground wire?? The way it was before it did and it went to the neg battery terminal. I have the field pole connected to the regulator. A y ideas here???
Old 07-06-2009, 06:53 PM
The Altenator Grounds through it's bracket normally.
Did you have the regulator tested? They can test those as well.
Do you have gauges or Idiot lamps?
Old 07-06-2009, 08:14 PM
Yeah they tested the regulator and it's fine. I gave gauges.
Old 07-06-2009, 09:38 PM
Franklin2's Avatar
With the truck off, take a meter and test for voltage on the "bat" terminal of the alternator. You should have 12v with the truck off. If you don't, then the fusible link is blown in that wire.
If you have that, then check the "a" terminal of the regulator. It also should have 12v with the truck off.
One of the wires going to the regulator should be red/green or green/red. Put your meter on this wire and the other lead of the meter to ground. You should have voltage on this wire with the key in run and the engine running. This wire will be located on the "I" terminal or the "s" terminal, however your setup is wired.
Old 07-06-2009, 09:55 PM
"S" terminal for Gauges.
"I" Terminal for Indicator Lamps.
This diagram is one I made for 1973-1979 trucks, but it's simular to 1980-1986's.
Old 07-07-2009, 09:10 AM
Thanks for the info guys. I'll be doing some tests when I get home!!!
Old 07-07-2009, 02:23 PM
What gauge wire should the power wire off the alt to the relay be?
Old 07-07-2009, 04:36 PM
Soo I'm looking at this stuff. I have 12volts at the bat terminal on the alt. Nothing at the A terminal on the regulator because the wire goes nowhere. Nothing is connected there. What is supposed to be there??
Old 07-07-2009, 05:04 PM
Well I hooked the wire for the A terminal like in the diagram and it's now charging 14 volts at 2000 rpm. Good enough for me!!! My ammeter isn't working but I'll take what I can get right now.
Old 07-07-2009, 05:12 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The OP's profile says 1984 F250, and he states he has a 6.9.
1983/85 F250/350: There are 7 different alternator wiring harnesses, SEVEN!
It makes a difference if the truck has a 40 - 60 amp alternator with gauges or with idiot lights.
Ditto for the 70 amp alternator.
If I knew exactly what the OP has, I might be able to locate a new original harness, that's been obsolete since grandma was a girl.
Old 05-24-2010, 11:35 PM
jls343 jls343 is offline
jls343 is starting off with a positive reputation.
pulling up an old thread off of a search. I have 83 f150 with guages and am having a problem with the charging system. When I start the engine, the amp meter pegs to full max for about five seconds and then starts to bounce systematically at an interval of about a second and a half. The lights dim in sync with the guage. I first replaced the regulator and then the alternator. I am getting a good ground to the engine block. On the diagram above, i see a capacitor coming off of the regulator. Any chance this could be bad and cause this? Any other suggestions? Thanks in advance for any help.
Old 05-25-2010, 12:02 AM
Franklin2's Avatar
Check the ground for the regulator.
97 blowing alternators tilliepeople 1968-2013 Full Size Vans 2 04-28-2015 09:26 PM
C5TB10A665E Wiring Harness gangstakr 1961 - 1966 F-100 & Larger F-Series Trucks 6 03-14-2015 01:28 PM
Gen/Alt Swap 1 wire verses 3 wire. Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 32 03-16-2014 02:45 PM
New Alternator/Batt...still no charge 04-F250SD 1999 to 2016 Super Duty 3 10-10-2010 02:15 PM
Alternator question ReAX Electrical Systems/Wiring 19 10-03-2006 06:47 PM
Tags
1983, 1984, 81, 97, alt, alternator, exlorer, explorer, external, f150, ford, issue, regulator, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
