Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-05-2009, 04:28 PM
dragford dragford is offline
dragford is starting off with a positive reputation.
2001 Oil pressure issue
2001 Expy, 5.4. Last week, every now and again, the oil pressure gauge would instantly drop below zero, the oil light would come on, and then 15 seconds later the gauge would pop right back to normal, and the light would go off. Today it started doing it every minute or so. I changed the oil pressure switch ($7.95) to no avail. Otherwise, truck is running well, and normal oil pressure registers as usual. To be clear, the gauge doesn't slowly drop and rise, it clicks off and on. Any ideas?
  #2 (permalink)
Old 07-05-2009, 05:51 PM
bnovak bnovak is offline
bnovak is starting off with a positive reputation.
Sounds like the connector at the back of the gauge is loose or corroding. Unfortunately, this means removing the dashboard and cleaning the contacts on the back of the cluster. On the good side, you can change any blown dash light bulbs
Only other thing I can think of is that it's actual connector at the sensor - might need to have it's connections crimped back togethor?
__________________
'98 EB Expedition
'08 Mazda MX-5 w/ Cosworth Supercharger
'69 Mach1 Mustang
'40 Chevy Pickup rust bucket project
'79 Wetbike * '94 Waveblaster raceboat
'01 Bluewater Skiboat
  #3 (permalink)
Old 07-05-2009, 08:18 PM
alloro alloro is offline
alloro is gaining momentum as a positive member of FTE. alloro is gaining momentum as a positive member of FTE.
Quote:
When the pressure drops does the engine make any additional or unusual noises that would lead you to believe there is an actual loss of oil pressure?
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #4 (permalink)
Old 07-06-2009, 01:35 AM
no
When the gauge drops and rises, there is no other evidence of anything else happening. If you didn't see the gauge actually quit and turn back on, you would never know it had happened.
  #5 (permalink)
Old 07-06-2009, 11:06 AM
Then I'd have to agree with bnovak that it is a wiring or connector issue.
__________________
  #6 (permalink)
Old 07-06-2009, 12:22 PM
heterodox1 heterodox1 is offline
heterodox1 is starting off with a positive reputation.
Mine did this on and off for about 3 years! (Especially in cold weather) I finally replaced the oil pressure sending unit and all is well. The sender is cheap to replace but it's a pain to get to. I see you replaced the sender already but it sure is acting like a bad one.
  #7 (permalink)
Old 07-06-2009, 07:33 PM
totalrecall totalrecall is offline
totalrecall is new and has a neutral reputation at this point.
Same for me - 2001 w/4.6. Had sending unit replaced and all has been well since.
Mike
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
