Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-05-2009, 04:07 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
Intermittent "stumble" on cranking
Hy Guys,
Ive got an annoying problem with my 97 4.2...Occasionally when its first cranked up it will shake like the dickens.About 50% of the time it will "catch up" and idle smoothly,and the other 50% it will die. If I attempt to crank it right away it fires up normally.
Fuel filter has been replaced,as well as a good cleaning of the IAC etc.
This only happens when its been sitting overnight,or at work when im in the office for 8 hours or so.Otherwise driveability is excellent(for 168,000 miles)...suggestions? there are NO codes,and the CEL lamp is operational.
  #2 (permalink)
Old 07-05-2009, 04:21 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
Not "up" on the 4.2 but if it only happens after sitting for 8 hours or so and starts right up after it dies, could it be your fuel is draining out of the fuel injector feed rail? Nothing more than a guess ...
__________________
In automotive since 1973, Ford from 1992 to 2006
ex-Ford dealership employee
  #3 (permalink)
Old 07-05-2009, 04:27 PM
n5926g's Avatar
Very good point..I have actually thought of possible weak/leaky injector(s) causing the problem.Im sure these are the original injectors.If the fuel rail pressure drops(while sitting overnight) I could see where it would cause a problem like this.Cant think of any other reason that the pressure would drop off unless there is a valve in the system that prevents"bleed back" into the tank.....Im just not completely convinced its a fuel deliverey problem...yet.
Thanks for the quick reply.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
