Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-05-2009, 04:00 PM
eaglestone eaglestone is offline
eaglestone is starting off with a positive reputation.
Trouble installing U-joint
We own a AWD 2000 Explorer, XLT. I've replaced the rear U joint (near the differential) a few times. After I replaced the original joint, I drove it around the block and came back to find smoke coming from the new joint. Replaced that one with another new one and I constantly hear a rubbing noise (can't explain the sound).
I can't think of anything I did wrong. I used a vise to push the old ones out and the new ones in and greased them before using the vehicle. Anyone else have this problem before?
  #2 (permalink)
Old 07-05-2009, 11:34 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Did you disturb the alignment of the roller??
check the resistance on the u joint before installing the shaft, you may have then to tight(pushed in too far)
  #3 (permalink)
Old 07-06-2009, 07:56 AM
When pressing the caps in, how to you prevent that from happening, and is there anything that can be done once you've pressed them to far?
Thanks for your response!
  #4 (permalink)
Old 07-12-2009, 01:36 AM
aquanaut20's Avatar
Yes,
  1. Don't push them in too deep when installing, AND
  2. gently back them out the same way you removed the originals.
Tags
installing , truck , ujoint
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
