Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-05-2009, 11:51 AM
taylorjgreen taylorjgreen is offline
taylorjgreen is starting off with a positive reputation.
76 to 65 Front End Swap Question
I have swapped the front end out of my 65 F100 with a 76. This was to get front disc brakes. Here is my question..
On the 65 axle there is a small bracket that bolted to the axle and then attached the frame. It looks like it is used to ensure the axle does not drop down too far.
On the 76 axle there is no hole in the frame or bolt to attach the bracket to. It seems like I just need to drill a hole in the axle and bolt the bracket on. What do I do??
  #2 (permalink)
Old 07-05-2009, 01:40 PM
65fordguy's Avatar
65fordguy 65fordguy is offline
65fordguy is starting off with a positive reputation.
You would be correct... on the 65 if the ibeams dropped below a certain level the springs would come out... on the 70s models there is a special washer that holds the springs to the ibeam and a strap at the top of the spring.
no factual info but I was told that the bracket didnt allow for full suspension travel under severe situations... and could cause an accident.
I just replaced mine with a 75 front end and used all the 75 parts, which meant I had to make a strap to fit the top of the springs.
--- who knows.
Good luck, you will be very happy you did this swap.. I love the power disc brakes... and power steering.
  #3 (permalink)
Old 07-05-2009, 03:03 PM
drof46's Avatar
drof46 drof46 is offline
drof46 is starting off with a positive reputation.
Do you still have the 76? Just grab the two straps and 4 bolts from the donar. Couple of holes drilled on each side and your ready to go.
__________________
1966 F-100 Custom Cab (work in progress)
351 Cleveland 4V (DOAE-J) *No its not a 351M**
C4 trans, 4.11 trac loc
Ground up resto. Ground is done, ran out of money for the up.
  #4 (permalink)
Old 07-05-2009, 05:39 PM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
Taylor, I run 76 I-beams under my 66 without the part you are asking about. No problems after about 7 years now.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #5 (permalink)
Old 09-07-2009, 09:59 AM
Thanks for the info. I think I will leave it as is
Tags
65 , 76 , brakes , end , ford , front , swap , trans , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
