Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-05-2009, 01:57 PM
99BlueOval 99BlueOval is offline
99BlueOval is starting off with a positive reputation.
NM, found the obvious ars bolt holding the harness on the otherside of the ECU. Damn, I just need to slow down a little
  #17 (permalink)
Old 07-05-2009, 02:08 PM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
Sorry I do not understand either question.
The pinouts for the ECU, EEC or PCM computers for the 5.0 are all in the same location on the plug for the OBD I.
The harness should be on the front of the ECU in the engine compartment with a 10 mm bolt head.
__________________
95 F150 302 4R70W EB EX-CAB
95 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #18 (permalink)
Old 07-05-2009, 02:16 PM
good short compter harness pin22 to diag pin6
HARNESS
good 12VDC pin1
good KO 12VDC 37 & 57
good GND 40 & 60
So it proves bad ECU?
  #19 (permalink)
Old 07-05-2009, 02:19 PM
Yea, thanks SUB. I knew the harness was held on by a bolt, but didnt comprend to check engine side of the firewall. I felt like a meat head when I found it, since I was tuggin on the computer for 5min, before i thought to check. DUHh
  #20 (permalink)
Old 07-05-2009, 02:26 PM
subford's Avatar
Quote:
HARNESS
good 12VDC pin1
good GND 40 & 60
Sounds that way but you could have one chip bad in the computer (you can open it up to look) the one that grounds pin #22.
Others have drove this way with a toggle switch on pin #6 of the test connector to ground.
But I would not recommend it for safety reasons.
__________________
subford@gmail.com
  #21 (permalink)
Old 07-05-2009, 03:03 PM
hey sub, Are both relays created equal?
For S&G i ohm'd out the pins on both & the green one has a 65ohm short pin#1-2... Brown is reading 1.5 Mohm same pins
  #22 (permalink)
Old 07-05-2009, 03:09 PM
I'm assuming these pins are the coil, & should be the same.
Green one bad?
  #23 (permalink)
Old 07-05-2009, 04:09 PM
ok i was wrong. A trip to autozone confirmed same resistance on both new relay coils... Any other tests that can help conlude bad computer?
  #24 (permalink)
Old 07-05-2009, 04:14 PM
subford's Avatar
I would think they would be close to the same. I think one of the two relays is rated at a little higher current capacity then the other.
__________________
subford@gmail.com
  #25 (permalink)
Old 07-05-2009, 09:55 PM
sub u called it, computer problems.!
opened it up & found a cap bad. I ran up to Radio Shack, thinking a fix was close....But, once i got it soldered in. i noticed an ic chip hiding behind a vertical PCB with a few pins that were also toasted. All the parts stores have to order it. So I'm hoping Rusty Acres (a local ford only parts yard) has one I can use.
You don’t happen to have a schematic of the EEC do ya? I'm curious if I did anything while I was working on the fuel system to cause the failure.
Figures, more money out of pocket, just to sell it. At least I did fix the annihilated gear on the passenger side window motor.
  #26 (permalink)
Old 07-06-2009, 07:45 AM
subford's Avatar
As far as I know there were at least three different manufactures making the computers for ford and from what I can gather they all used a different diagram to make the same thing. You can open two up with the same part number and program number an they will be very different. They will even use different chips and chip manufactures.
Here is a diagram of the circuit you have been working with from one computer:
__________________
subford@gmail.com
  #27 (permalink)
Old 07-09-2009, 10:20 PM
Follow up
Almost forgot, 80 bucks later for a new computer & the truck started like nothin happened.
Thanks again Sub, for helping me through the troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
