Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-05-2009, 10:58 AM
esebm esebm is offline
esebm is starting off with a positive reputation.
Lower brake lights don't work
Hi,
On my 04 Escape only the upper brake light works but not the lower ones. Are those 3 lights not triggered by the same switch?
Thanks,
Ed
  #2 (permalink)
Old 07-06-2009, 09:36 AM
budwich budwich is offline
budwich is starting off with a positive reputation.
well.... yes... in a "way". The brake switch "starts" things off for both types of lighting BUT the wiring goes thru different systems to cause the "flash". The third light is simple (basically "straight" thru wiring) BUT the others get their "lighting orders" from the smart junction box (at least in my 2005 drawings... hopefully 2004 is not much different). You need to go to the bulbs and check them first to see if they are good and then for voltage when you hit the brakes. From there, that will determine what else you need to trace. PS. each side gets its voltage from a different "source" at the SJB.
  #3 (permalink)
Old 07-06-2009, 10:47 AM
Seems sort of weird, doesn't it?
I just checked way down at the brake pedal and there seem to be two different switches.
I was wondering if someone had a piece of drawing for the 2004?
Thanks,
Ed
  #4 (permalink)
Old 07-06-2009, 12:50 PM
Again yes BUT they are not both for your brake lights.... one is for brakes, the other for speed control "control" (as in deactivation).
  #5 (permalink)
Old 07-06-2009, 01:25 PM
Makes sense, thanks.
So, where is this SJB located?
  #6 (permalink)
Old 07-06-2009, 01:45 PM
I don't think that you want to go there at least at this point. Follow the suggestions for trouble shooting. Note that the smart junction box is located under the console and probably not the cause of your problem IMO.... but we have only owned our escape for a year.
  #7 (permalink)
Old 07-06-2009, 02:33 PM
Okay, trouble-shooting.
I sort of doubt that 2 bulbs blow at the same time, I'm pretty certain that there's no voltage getting to the bulbs when I hit the pedal.
If the voltage for both sides come from a different "source", doesn't that automatically point to this SJB? Does this thing have a separate fuse?
  #8 (permalink)
Old 07-06-2009, 03:05 PM
well as for "bulbs don't go at the same time", how do you know they went at the same time????? bad assumption. Multitudes of people don't go around looking at their lights either front or back....because they are "busy" driving their vehicles, not running in front or behind them. Hence, one light goes out and over a period of time, weeks, months or otherwise, the other goes out..... certain not at the same "time". Very common. Again, Check for voltage and go from there. From what I can tell, you don't want to f.... with the SJB as "everything" goes thru there and you are likely asking for trouble poking in there for basically "no reason".... that's probably why they made it "relatively inaccessible". Further IF there was a problem there, you would likely notice significant other numbers of problems.
  #9 (permalink)
Old 07-06-2009, 03:19 PM
In general, you are right. However, I happened to see my wife leave our driveway a few days ago and all 3 brake lights came on. Of course, they still could have been blown a minute or so apart, I guess. :-)
I'll check the bulbs and voltage.
Thanks,
Ed
  #10 (permalink)
Old 07-06-2009, 09:52 PM
Presents of voltage or lack there of will tell you more than just guessing..... and lead you in different directions depending on the outcome. One towards the voltage source the other to a grounding issue.
Tags
brake , lights , lower , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
