Need more info on what truck you have, year, engine, etc. There are two locations of fuse/relay boxes one under the hood other under the dash on drivers side. If it's your brake light switch it's under the brake pedal's arm/lever. No need to pull the dash apart as far as I can tell with what little info you provided.
Good luck!!
__________________
Scott
99 F250 SD/SC XLT 6.8L/415ci, 6" lift, 156,000mi
94 Ranger SC XLT, 4.0L/244ci, stock, 191,000mi
93 Thunderbird LX, 3.8L/232ci, stock, 220,000mi
Blue blood here!
