Update on driveline vibrations - Page 3 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #31
Old 07-14-2009, 03:12 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Probably just the casting. Jack it up and see if it spins true while in gear.
  #32
Old 07-14-2009, 04:21 PM
SFeintuch's Avatar
SFeintuch SFeintuch is offline
SFeintuch is starting off with a positive reputation.
This may sound stupid but is your vibration damper in place on the rear of your trans? Just a thought it may be missing. Sounds like your going through hell. Hope you get to the bottom of it soon.
  #33
Old 07-14-2009, 04:38 PM
Quote:
He said he had 2 of them on page 1.
  #34
Old 07-14-2009, 04:41 PM
dave91gt dave91gt is online now
dave91gt is gaining momentum as a positive member of FTE.dave91gt is gaining momentum as a positive member of FTE.
Both there.
I cant say this enough that I appreciate you giving me ideas and feedback. If this were any other vehicle, I would have already traded it.
  #35
Old 07-14-2009, 05:46 PM
Hang in there, it is prominant and continous enough that you will find it.
  #36
Old 08-01-2009, 04:35 PM
mopnup mopnup is offline
mopnup is starting off with a positive reputation.
Going thru same thing
I am having the exact same problem with my 03 diesel ex. I have not put the extent of work you have at this point but I am about to start. Just came back from a vacation trip and it shook me to death. My daughters friend was scared it shook so much. It has been this way for a while, but I am not at the point where i must find a cure.
  #37
Old 08-28-2012, 10:48 AM
wapiti57 wapiti57 is offline
wapiti57 is starting off with a positive reputation.
Lateral Misalignment between the TC and Pinion
I am having vibration issues too. I have checked the center bolts and they are okay. I noticed there is a dog-leg at the carrier bearing, it is off about 3/8 of an inch, to the left. I called the driveline shop this morning and they said that the lateral misalignment is normal. Also he told me that they cut off the vibration damper and balance the shaft because the harmonic balancer is just trouble.
  #38
Old 12-06-2013, 10:30 PM
Dave Brawley Dave Brawley is offline
Dave Brawley is starting off with a positive reputation.
Did you ever solve these vibrations? Im having them now.. I have the one original driveshaft, with 2 new ujoints... My vibration dampener on the driveshaft looks like the rubber is cracking..
I plan to order a new driveshaft and Endpieces all as one unit and having it balance by tom in Utah. I have not torn into the rear end ever.. the helicopter noise best describes it, but at a higher frequency.. its not comfortable to ride.. it has 167K miles..
I am also hitting the front end shop for an alignment, ball joint check and front bearing check just to be safe.. Mine just started all of a sudden.. I also changed to new tires, and they balanced the rims dry and then the rim/tire..
This is a higher frequency vibration than the tires can do.. I feel in my gut its driveline related.. Changing U joints didn't fix it..
  #39
Old 12-09-2013, 11:37 AM
wolfboy's Avatar
wolfboy wolfboy is offline
wolfboy is starting off with a positive reputation.
driveshafts
dude the driveline shop is full of @$%^^%^ im a drive line teck ive been buil;ding for 20yrs if thers slop in th slip yolk thers a problem also if the lift is to tall you need to high angel the drive line and never trust a driveline shop tyhat says loose is ok!
  #40
Old 12-09-2013, 11:40 AM
wolfboy's Avatar
call me for issues with drivelines im in phoenix and i ship all over i also fix alot of tomms drivelines 602 997 0906
  #41
Old 12-10-2013, 05:53 PM
wolfboy's Avatar
driveshafts
hey did you fix it yet
  #42
Old 12-10-2013, 05:54 PM
wolfboy's Avatar
driveshafts
i getb rid of thes from the start and stuff with foam to rid harmonics
  #43
Old 12-30-2013, 05:55 PM
az_r2d1 az_r2d1 is offline
az_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud of
Mine also has an odd vibration when cold.
Had an alignment check done today. Sure enough, it has 1 wheel with play (wheel bearing), other wheel has a bad top ball joint, some play on the tie rod going to pitman arm. And he said the steering box is bad. Doh.
Most if not all i can do myself.
Its a 2wd so bearings should be easy and cheap. Not sure yet on ball joints on 2wd.
  #44
Old 12-30-2013, 09:34 PM
Curt's05's Avatar
Curt's05 Curt's05 is offline
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
Oem Fix maybe; Upgraded ford driveshaft part # 3C3Z-4602-AL The 2 Spicer u-joints with 4 different thickness retainer clamps non grease able part # BC3K-4635-A
Pinion angle? Jointasset Excursion - King of SUVs 9 07-05-2016 09:24 PM
Chasing Vibration..... BigBad408 Excursion - King of SUVs 16 05-24-2016 10:02 AM
Bad vibration in rear end, after doing a lot of work. RedDevil460 1999 to 2016 Super Duty 36 04-13-2016 04:56 PM
Chasing a Vibration Tom Excursion - King of SUVs 25 04-06-2013 08:33 AM
Driveline vibrations Boba Fett 1973 - 1979 F-100 & Larger F-Series Trucks 14 11-01-2011 11:19 PM
Tags
03, 2008, 91, bracket, center, drive, driveshaft, excursion, f250, ford, joint, line, low, mustang, sd, support, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
