12 inch lift springs
A buddy of mine is in the middle of building a 1979 ford f-350 with a 12 inch supension lift, problem is the rear axle wraps extremly hard on even slight acceleration... does anyone know of a comapany that makes traction bars for somthing like this or has anyone made their own that would like to help me out with some ways to build my own. thanks
make sure all the leaves are clamped together
can't remember my length measurements and don't feel like going outside or to the garage. wtf do you have to add as to importance kirby???? pretty sure the s/d springs were 53'' and 3/4's eye to eye but didn't write it down. how much of a difference are we talking???? never read much on people having too much difficulty swapping them, only heard about better price, flex, lift, and swapability, better shackle angle too.
Dan hit on all the points. Yes they are longer but that only makes everything associated with having springs too long that "could" be a problem actually better.
It lays the shackle back to a more ideal angle. Some have used longer shackles on higher lift/flex situations to keep the spring eye from hitting on the frame but I dont think thats necessary for your average mudder.
Raymond, that sounds like a really big block to be stuffing in there for lift. I would think the taller the block, the more likely it would be come out of there unexpectedly. I have always heard that tall lift blocks are a bad idea, anyways. Just do a search on how to measure for shocks. The front is going to be tricky I think because you have coil springs on the front, unless you modified the stock suspension for some other setup. I don't know that you can get that much lift from an aftermarket coil spring, unless you make some kind of offset upper or lower bucket to hold the spring.
RJ sheedy
12-13-2016 02:01 PM
2.5itim
18
09-06-2016 01:53 PM
