12 inch lift springs - Page 2 - Ford Truck Enthusiasts Forums
Old 03-03-2011, 10:24 PM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
well being as you have a summit within driving distance go that route, gonna be cheaper even with my discount code on the other site. i have another thing for them where i get like $40 off my next order i think, but it might have a quick expiration date.
Old 03-06-2011, 01:59 AM
Kirbys73F100's Avatar
Kirbys73F100 Kirbys73F100 is offline
Kirbys73F100 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by fatdan460 View Post
hey redneck, i got a place where you can get 4'' or 6'' s/d front leafs for that truck for like $250-280 a pair shipped. they are damn near a bolt in for the leaf sprung front 79's and older. let me know if you are interested.
no theyre not
Old 03-06-2011, 02:00 AM
Quote:
Originally Posted by master_mechanic View Post
A buddy of mine is in the middle of building a 1979 ford f-350 with a 12 inch supension lift, problem is the rear axle wraps extremly hard on even slight acceleration... does anyone know of a comapany that makes traction bars for somthing like this or has anyone made their own that would like to help me out with some ways to build my own. thanks
make sure all the leaves are clamped together
Old 03-07-2011, 10:44 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Quote:
Originally Posted by Kirbys73F100 View Post
no theyre not
Yes they are. Drill the front hanger hole out to 3/4" and drill the bushing out to 3/4". To me thats "pretty much bolt on"
Thats your solution to axle wrap?
Old 03-07-2011, 11:13 PM
Theyre a different length genius
Old 03-08-2011, 03:30 AM
can't remember my length measurements and don't feel like going outside or to the garage. wtf do you have to add as to importance kirby???? pretty sure the s/d springs were 53'' and 3/4's eye to eye but didn't write it down. how much of a difference are we talking???? never read much on people having too much difficulty swapping them, only heard about better price, flex, lift, and swapability, better shackle angle too.
Old 03-08-2011, 07:58 AM
Dan hit on all the points. Yes they are longer but that only makes everything associated with having springs too long that "could" be a problem actually better.
It lays the shackle back to a more ideal angle. Some have used longer shackles on higher lift/flex situations to keep the spring eye from hitting on the frame but I dont think thats necessary for your average mudder.
Old 04-17-2014, 09:24 PM
Raymond Tomlinson Raymond Tomlinson is offline
Raymond Tomlinson is starting off with a positive reputation.
Help
I justed did a rear shackle flip on the rear of my 79 f150 and with 6inchs of block it gave me 12 1/4inchs of lift but need shocks and a way to do the front next any ideas or add on
Old 04-21-2014, 10:10 AM
bigdan1979f-250's Avatar
bigdan1979f-250 bigdan1979f-250 is offline
bigdan1979f-250 is starting off with a positive reputation.
Raymond, that sounds like a really big block to be stuffing in there for lift. I would think the taller the block, the more likely it would be come out of there unexpectedly. I have always heard that tall lift blocks are a bad idea, anyways. Just do a search on how to measure for shocks. The front is going to be tricky I think because you have coil springs on the front, unless you modified the stock suspension for some other setup. I don't know that you can get that much lift from an aftermarket coil spring, unless you make some kind of offset upper or lower bucket to hold the spring.
9 inch lift kbrenner536 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-08-2012 11:57 PM
38 inch tires on 4 inch lift? lucaslaw 1999 - 2003 7.3L Power Stroke Diesel 11 11-09-2010 06:01 PM
f150 302 horsepower muddinf150 1987 - 1996 F150 & Larger F-Series Trucks 15 05-27-2010 11:17 AM
any one w/ pics of fender flares FOUNTAIN 1 1999 to 2016 Super Duty 18 05-05-2009 12:13 AM
Homemade 2wd Ranger lift BlueOvalDrifter88 Offroad & 4x4 4 10-12-2005 01:10 AM
Tags
1025, 12, 2003, 79, end, f150, f250, ford, inch, lift, mud, rear, springs, sterling, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
