Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 06:56 PM
Violeta Violeta is offline
Violeta is starting off with a positive reputation.
#4 spark plug constantly fouls
Hi all. I have a lemon-y 1998 Ford Explorer (Exploder) 6 cylinder engine that two, three times a year has the "Check Engine" light come on and it's always the sdame thing: misfiring #4 spark plug cylinder. Problem resolves by replacing the plug (no one "re-gaps" anymore do they?). Question is: which plug is the #4 plug since I'd like to try replacing it myself? If I am standing in front of the open hood, is it on the passenger side of the car or the driver's side? And once the side is determined, is it the plug closest to me (the grill), closest to the firewall (farthest from me), or in the middle? Trying to avoid an $80 charge for what I know is a plug replacement from the dealer. Thank you!
  #2 (permalink)
Old 07-05-2009, 03:03 AM
pbjohns pbjohns is offline
pbjohns is starting off with a positive reputation.
# 4 is at the front driver side of engine, close to the left front head light.
  #3 (permalink)
Old 07-05-2009, 10:21 AM
Bear River Bear River is offline
Former Vendor
Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE.
The problem is that you need to figure out why that plug is fouling. Just a word of wisdom up front, get the genuine Motorcraft double platinum plugs for this job. RockAuto.com always has them and at good prices. You can use the OE spec Autolite double platinum as well, it is the same thing as the Motorcraft.
As for why the plug may be fouling, you could have a intake leak leaning it out, a dirty of plugged injector that is either leaning it out or getting stuck open, fouling it out. You could have a leaky valve stem letting excess oil in. I would rule out rings for now, because leaking rings that are bad enough to foul a plug will almost always trigger a CEL by themselves. Take a look at the plug, and if its not too much trouble, post a picture of it on this forum.
  #4 (permalink)
Old 07-05-2009, 03:23 PM
#4 plug constantly fouling
Ah ha! You are of course correct in asking WHY this plug fouls frequently when the others do not. We bought the Explorer used (Red Flag #1). When we started having mechanical problems with it, we took it to both Ford and then an independent dealer. Ford replaced a number of things on it ($$$) that had nothing to do with the actual problem itself (they replaced the "shift motor", etc.). The independent garage told us that there is a crack somewhere (I forget where, honestly) that is allowing, over time, coolant to be contaminated with oil and vice versa. (Serious problem, actually, although it happens very slowly). His advice? "I'd be looking to get rid of it." Which is probably true. However, what I elected to do was monitor fluid levels and cleanliness frequently (4 - 6 times a year) and change those when there is a problem; and change the plugs twice a year. All this is being done for me by a mechanic. They generally are telling me things are acceptable, the plugs are ok, but the #4 plug will keep fouling. I am going to drive it into the ground but I treat it as carefully as I know how. Just one of those things...what can you do? I also have a Toyota RAV4 2006. No problems to speak of, yet. Thanks for your help and insight - I do appreciate it!
  #5 (permalink)
Old 07-05-2009, 03:35 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Had a similar problem with #3, misfire every +-3000km, finally re threaded the SP hole, installed a cooler plug, and 40K later have had no further problems.
My guess, either it was running to lean(hot) or not a good conduction to the block (too hot) or poor electrical connection, (weak spark).
Only con, loss of 2MPG in cold weather.
BUT, if it works, don't fix
  #6 (permalink)
Old 07-05-2009, 03:39 PM
  #7 (permalink)
Old 07-05-2009, 03:47 PM
Tags
2006 , fouled , location , mountainee , number , plug , plugs , spark , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
