Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 06:02 PM
radramrod2 radramrod2 is offline
radramrod2 is starting off with a positive reputation.
Poor idle - 91 351W to 95 351W Roller Cam
Recently replaced a worn '91 351W non-roller cam in a '91 F150 w/ E4OD, with a roller cam unit out of a '95 F250. Overall, the truck runs great and performs as expected, all but the idle quality.
When cold, computer just connected, the engine "tries" to idle around 800-600 rpm, but just cannot hold it (irradic) and will return to 1000 rpm. It will stay there for several minutes & sits around 900 rpm while in DRIVE and at rest, it will do this all day long and is fine, but it will not idle, EVER, where it should around 600 rpm. I have checked for vacuum leaks, replaced IAC...all gaskets (intake - upper/lower, throttle body, IAC, PCV valve, all hoses/vacuum lines have been replaced and gone through), I'm certain there are no vacuum leaks, it holds around 18" HG when at 900 rpm. When cold, and the IAC is unplugged, the engine will idle at 600 rpm, but when it's warm, it stays about 1000-900 rpm. I have gone through and checked TPS voltage and set it up accordingly, even though it didn't need adjustment. Throttle cable is brand new & not sticking.
I'm all out of ideas as of what to do? Is this the roller cam causing this issue? Or do I need to rewire something? All stock components were reused off of the '91 engine, including the distributor/wiring harness, but with a new steel gear just for the roller cam. This is a speed density system, in case anyone wanted to know.
I can live with the way it runs as of now, but it irritates me to have to deal with this idle issue, if you have any thoughts, please let me know!
  #2 (permalink)
Old 07-04-2009, 07:12 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Assuming you also installed the '95 roller lifters and pushrods too?
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #3 (permalink)
Old 07-04-2009, 07:58 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
95 had roller cams?
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #4 (permalink)
Old 07-04-2009, 08:03 PM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Diesel_Brad View Post
95 had roller cams?
Yes. 351W had roller cams starting in 1994.
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #5 (permalink)
Old 07-04-2009, 08:06 PM
1980 Ford F-350
My Garage
Not my lightning or the 95 lightnings
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #6 (permalink)
Old 07-04-2009, 11:34 PM
Conanski's Avatar
1990 Ford F-150
yes that's right... for some reason the Lightning got a special flat tappet cam.
__________________
Paul O
  #7 (permalink)
Old 07-05-2009, 02:36 AM
choochoof150's Avatar
choochoof150 choochoof150 is offline
1995 Ford F-150
choochoof150 is starting off with a positive reputation.
The 1st gen lightning block is designed to have a roller cam so all you have to do is get 5.0/5.8 roller lifters, bones and retainer. Then just drill and tap two holes to mount the retainer in the valley and shop for your roller cam of choice.
  #8 (permalink)
Old 07-05-2009, 12:00 PM
1980 Ford F-350
My Garage
Not all 1st gen are roller ready. 93's are not. somewhere early 94 they came roller ready, 95 are roller ready
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #9 (permalink)
Old 07-05-2009, 06:31 PM
Yes. The motor is all stock as of yet, including the factory roller lifters and pushrods. The only items I switched over were the accessories from the original motor. Everything else is from the donor, all except the computer. New gaskets were installed at the time the motor was put in.
Tags
351 , 351w , 95 , cam , cams , density , ford , iac , idle , iron , ranger , roller , rpm , truck , unplugged , xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
