Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 05:31 PM
deyomatic deyomatic is offline
deyomatic is starting off with a positive reputation.
Fordomatic Tranny Cooler question
There are two coolant hoses that go into what I can only guess is some kind of transmission cooler for the Fordomatic in my '60 F100. It seems like one is shorter and goes to the block and the other goes to the water pump. In my ulitmate attempt to remove this engine and tranny, I removed the line that seemingly goes to the block at this cooler and A LOT of coolant came out...
Could that have drained the block, too?
  #2 (permalink)
Old 07-04-2009, 06:06 PM
Old F1 Old F1 is offline
Old F1 is starting off with a positive reputation.
Are you sure that these are not going to the cab heater?
  #3 (permalink)
Old 07-04-2009, 11:56 PM
Yeah, I had to look at it a few times...There's two hoses coming from the heater, one goes to the passenger side of the water pump, the other goes to the intake fitting. There is a third line that is visible from under the hood that goes from a fitting on the right side of the water pump, up and over the passenger side valve cover and behind the engine. From below the truck, on the passenger side of the Ford-O, there is a box about 4" x 7" where this hose connects. There is a second fitting on that little box that feels like it goes straight to the back of the engine, but visibility is limited.
All I know is, it's my first experience with it and I kept muttering (and yelling) "...(Expletive deleted)...another one of Ford's BETTER IDEAS!!"
  #4 (permalink)
Old 07-05-2009, 12:43 AM
So if automatic transmission fluid can be cooled (?) by piping it into a tank inside a hot radiator full of antifreeze then I guess automatic transmission fluid can be cooled by piping hot antifreeze back to it, …………..it has to be some kind of trans cooler.
  #5 (permalink)
Old 07-05-2009, 09:25 AM
Yeah, it still just seems like an odd design. Oh well. I was just wondering if anyone knew how much MORE coolant might be in this engine. I'm almost to 5 Gallons between the radiator and this hose.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
