Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 05:02 PM
camperspecial65 camperspecial65 is offline
camperspecial65 is gaining momentum as a positive member of FTE. camperspecial65 is gaining momentum as a positive member of FTE.
hard starting/clicking sound
91 3.0, 2WD, Mazda 5 speed...Im having a heckuva hard time...to put it very mildly to get my truck started...99 out of 100 times when i try to start it, all I get is the single clicking sound which I believe to be from the starter relay. Everything is original except the starter which is a wrecking yard replacement..a couple of years ago...but a clean one that had previously been rebuilt...
Ive always thought it to be the 3 position switch at the clutch master shaft at the pedal...I swapped it out with another and no difference..
Once the starter does get juice to it and engages it fires no problem ...same as always...its just a matter of no starter action...just the clicking at the relay...battery is new btw...definately not an issue.
Im at the point now that Im thinking the starter itself is toast(brushes?) or the starter relay...suggestions ???
BTW..all connections are good and clean, zero corrosion and so on...just needing the starter to kick in and crank..
- cs65
  #2 (permalink)
Old 07-04-2009, 05:32 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Try this simple litle test. Remove the connector with the rubber boot from the starter relay. Jump 12 volts to that terminal.
If it cranks, the problem is between the ignition switch & the starter relay.
In my case with my 87 Ranger it did NOT crank.
So I jumped from the negative post on the battery to the engine block. BINGO, it fired right up & I swapped the negative battery cable. Problem solved.
  #3 (permalink)
Old 07-05-2009, 12:10 AM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
The brushes in the starter are worn down to the point where they usually don't conduct electricity correctly except for that one time out of 100 when the brushes are aligned with the correct spot on the shaft.
Replace brushes in starter is the cheap solution.
New starter is the old expensive method.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
