Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 03:00 PM
SaikotikGunman's Avatar
SaikotikGunman SaikotikGunman is offline
SaikotikGunman is starting off with a positive reputation.
Reuse U-Joint retainers?
Have a new U-joint that came with my truck when I got it, and the back one has a lot of slop, so I figure that's why. I've been greasing the Hell out of it, and that keeps the clunking and squealing away, but I've got a couple hundred mile trip coming up, so it seems like a good time to put the new joint in, especially since this particular trip has in the past claimed two U-joints, one driveshaft(which took the exhaust pipes with it), and cracked a bell housing spread out over two vehicles... I've never changed one myself, but I figure it's gotta be a simpler task than many of the repairs I've recently tackled. The book outlines the procedure, but says most new trunnions come with new snap-rings, but the one I have did not, hence the question: are they reusable?
__________________
1995 F-150 XL 4x4 5.0L 5-speed ~65k
-8' Flatbed, 1-ton+ leaves, 4" lift, 35" Mud Kings on spare set of aluminum rims
1987 F-150 Custom 4x4 5.0L auto ~202k
1985 F-250 4x2 351 auto -Potential project truck-
RIP: '88 F-150 Custom 4x4 4.9L 5-speed, '87 F-150 Custom 4x4 4.9L 4-speed
  #2 (permalink)
Old 07-04-2009, 03:18 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
i would not reuse them. They are prob the wrong joint if they did not come w new retainers
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #3 (permalink)
Old 07-04-2009, 04:04 PM
Looks like the right joint, and it's still in the packaging.
I'm trying to figure out how a truck with 64k miles is ready for its third set of U-joints(the work one has a zerk, I don't think the factory ones did(?). The previous owner must not have been the preventative maintenance type, from other things I've noted, but still. Guess the 35" tires must have been a lot of extra stress on the driveline.
__________________
  #4 (permalink)
Old 07-04-2009, 04:06 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
1994 Ford Mustang
My Garage
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
Are you talking about the caps that bolt onto the yoke? I've never seen a new u-joint with new caps. All of the u-joints I have done come with new retainer clips though.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
http://mistercmk.com/images/sig.jpg
Quote:
Originally Posted by tcbofade
I have no brain
  #5 (permalink)
Old 07-04-2009, 09:31 PM
Found them. They fell out of the package in the glovebox, and got mixed up with the assorted mass of Copenhagen coupons and convenience store receipts I also inherited with the truck.
__________________
  #6 (permalink)
Old 07-04-2009, 11:31 PM
Dre82s Dre82s is offline
Dre82s is starting off with a positive reputation.
The Job is simple all you need is a fresh can of penetrative additive a hammer and spike so you can beat the u-joint out, about 45 min took me to do the entire rear shaft, including a beer break or two.
  #7 (permalink)
Old 07-05-2009, 12:21 AM
optikal illushun's Avatar
optikal illushun optikal illushun is offline
optikal illushun is starting off with a positive reputation.
couple of tips, after getting the joint out sand the inside with some emory cloth or fine grit paper and use anti-sieze to aid in installation and later removel if needed.
also, i would not use a spike. i have one old socket that is barely bigger then the cap and one socket that is just slightly smaller than the cap with an extension i use to pound the joint out. a shop vice is also handy and will work better. best way is to use a ball joint press and the easiest is to use a red wrench and cut the joint in an X in the body. also, u may have to re-bend the ears a little i severe persuasion is needed in removal.
as to the oringal question, yes i have re-use the retainers for the outside over. as long as they lock into the groove its ok. would i recommened it? not if new ones are available. as for the other style which goes in the inside and looks like a C, no i wouldnt re-use them as most are damage in extraction. have i in the past? u bet. anything to get back on the road again :-)
__________________
93 F150 XLT 4x4 Modded 300/Built E4OD/SAS-79 Dana 44-5" lift/33" ProComp MTs/15x8 AR 147's/Crane 503905 cam/Ported intakes/V8 throttle body/Hedmen headers/some kinda exhaust/Crane coil-Taylor wires/Cervini's RamAir hood/Diamond lights/Infinity-stereo
1988 F350 Custom 4x4 7.3IDI/ZF/RayWel lid w/ Opti'ized ram air/"G" codes/True 2.25" duals/315-75-16 ProComp Xtreme ATs/16x8 White waggies/Alpine-Infinity stereo
  #8 (permalink)
Old 07-05-2009, 06:48 AM
fmr9 fmr9 is offline
fmr9 is gaining momentum as a positive member of FTE.
If the u joint is really tight, you can damage or break something by beating it out. Advance and Auto Zone have a tool loan program. You can get a ball joint/ujoint press from them. It works really well. Makes the job very easy. I also used an impact wrench to run the press, but a big breaker will work too. A little duct tape will keep the caps on until you install it in the truck. Putting all those bearings back after the cap falls off is not fun.
Good Luck
Frank
__________________
BUFF " Butt Ugly F***ing Ford"
90 Ford 205,000 miles, 4.9, E4OD, 4X4, 3G alternator.
  #9 (permalink)
Old 07-05-2009, 07:25 AM
jr32560's Avatar
jr32560 jr32560 is offline
MD Chapter Ldr
jr32560 has a great reputation on FTE. jr32560 has a great reputation on FTE. jr32560 has a great reputation on FTE. jr32560 has a great reputation on FTE. jr32560 has a great reputation on FTE.
Quote:
Good Luck
Frank
I agree on the little needle bearings-they will make ya loose your religion quick ,fast and in a hurry
and on a second note -if the caps seem to not quite go into place and your sure it's the right joint-sometimes one little needle bearing will get out of place and lay on top of the center part of the joint-just enough to keep the cap from going into place-not a bad job if luck is on your side-good luck-once ya do it once-you will have it down pat!
__________________
Junior Hardy-Md Chapter Leader
1990 F150 302
1995 E250 4.9
member of the Boy you ain't Right club #4
President of the crap shooters club
Join the Maryland Chapter click HERE
  #10 (permalink)
Old 07-05-2009, 08:53 AM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 is gaining momentum as a positive member of FTE.
What I do to keep those needle bearings in place is fill the cap up with good grease before you put the cap into the yoke. When you put the cross in the grease will spred out but those needles should stay put. Its a real pain to find one stuck like Jr32560 said!
__________________
89 F250 2x4 302/AOD 4.10 gears ,now on road.
89 Bronco2 with dead A4LD again
84 F250 4x4 300/np435 3.55 gears. The BLUE MULE shut down due to cab cancer(looking for good cab)
95 E350 bus conversion 460/E4od 4.10 the new toy!
85 Plymouth Caravelle 2.5L someday to get the hairdryer treatment(turbo)
93 explorer now just a woods buggy
  #11 (permalink)
Old 07-05-2009, 09:34 AM
Sounding less fun all the time.
Should I grease the tar out of it right away once it's on, or is there enough grease in a new joint to last a few miles?
__________________
  #12 (permalink)
Old 07-05-2009, 09:46 AM
jr32560's Avatar
MD Chapter Ldr
a lot of times it's almost impossible to grease them when installed -he is what i do-after ya get em in the front yoke-and all is left loose are the 2 caps on the rear-grease the front one till ya see the little rubber cap seals swell slightly-then use a bench vise or a big c clamp on the 2 loose caps-to hold em in place and grease the rear one let it sit a few minutes-so the pressure won't push the caps off-then install the driveshaft-most times once the driveshaft is installed they are a bear to grease-I will pull it loose and grease em once in a while-if i remember it when I'm under the truck and doing other things-usually never they never seem to put the grease fittings in a place ya can get to it to grease em
__________________
1990 F150 302
1995 E250 4.9
  #13 (permalink)
Old 07-05-2009, 09:48 AM
jr32560's Avatar
MD Chapter Ldr
oh just to let ya know-99% of all shops do not grease the u joints when they do a normal oil change/grease job-I'm gonna catch heck for this statement but it's true!
__________________
1990 F150 302
1995 E250 4.9
  #14 (permalink)
Old 07-05-2009, 09:55 AM
jr32560's Avatar
MD Chapter Ldr
honestly they aren't that hard to replace-only a shade tree mechanic myself and I've been doing since I was 16 years old-and your getting top quality tips by checking on this site-i had no clue how to replace em back in 1976-but i got em in and they stayed-so I learned the hard way good luck and post back if ya run into any problems
__________________
1990 F150 302
1995 E250 4.9
  #15 (permalink)
Old 07-05-2009, 10:01 AM
Quote:
I'm not concerned about getting to the grease fitting once it's put together. Growing up on the farm, I've gotten a lot of practice reaching grease fittings in places that would give you nightmares. Engineers go out of their way to make things difficult for us, don't you know?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
