Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 02:40 PM
jimistephen jimistephen is offline
jimistephen is starting off with a positive reputation.
what to do?
Here's the story, I was buying a 07 ranger off of a guy when he called and said I need the truck back, as nothing was in my name I was kinda screwed. A guy I go to church with sold me a 93 f150 4x4 with a 300 and a 5spd. I've been looking for a good truck to put a 4bt cummins into. So I pose the question to all you wonderful men and women. should I keep the 6 or put the 4diesel into it?
~stephen
  #2 (permalink)
Old 07-04-2009, 02:48 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
Run it as long as it works and does what you want it to while you gather parts for a swap. I think it would cooler to have a bt4 in a ranger, but if you need a fulsize, stick w the f150
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #3 (permalink)
Old 07-04-2009, 03:18 PM
frankyford frankyford is offline
frankyford is starting off with a positive reputation.
I would think a diesel would be too strong for that truck, you may be looking at reinforcing the frame from twisting from too much torque. If not now it could gradually happen over time.
__________________
Frank
Stockbridge, Ga
  #4 (permalink)
guitarnik's Avatar
guitarnik guitarnik is offline
1990 Ford F-250
guitarnik is starting off with a positive reputation.
same thought
__________________
90 f250 4x4 5-speed 351w headman LT's 33x12.5 coopers CHEVROLET-Cheap Hardly Efficient Virually Runs On Luck Every Time
  #5 (permalink)
Old 07-04-2009, 03:22 PM
If the frame didn't twist right away you'd be lucky, but you would definitly have to change to a stronger rearend spline and gear setup. I t would brobably break right away. There would be a whole lot to consider, the cheaper route would be to find a diesel truck.
__________________
Frank
Stockbridge, Ga
  #6 (permalink)
Old 07-04-2009, 03:26 PM
1980 Ford F-350
My Garage
too strong for what? the ranger? Al ready been done
here is one http://www.dieselpowermag.com/featur...ger/index.html
here is another
http://www.dieselpowermag.com/featur...ins/index.html
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #7 (permalink)
Old 07-05-2009, 12:16 AM
Yeah the 4bt is not like the 6bt, were talking about 140 hp, 300-350 ftlbs. If I do the swap I will be driving it until I have everything, has it's my only rig right now. I want diesel because it's less parts to maintain. Can run about anything through it, from veggie oil to tranny fluid to waste motor oil, kerosene, etc. Power band is on tap right off throttle. They last longer(although the 4.9 last a long time also.) Right now it's my only rig, but in the future I plan on getting another truck and fixing this one up a bit(couple of rust spots, new interior, etc.) While doing that I was going to rebuild the engine, but really want a diesel so I thought about going with a 4bt with it. I'm not sure what the 4.9 weighs but the 4bt is 750lbs. I don't know, I might just drive it until the doors fall off and then push it over a hill.
  #8 (permalink)
Old 07-05-2009, 12:26 AM
cchimuk cchimuk is offline
cchimuk is starting off with a positive reputation.
I have had diesels in the past and love them, The conversion is too big a project for me to do but it would be fun to try.
  #9 (permalink)
Old 07-05-2009, 12:35 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Quote:
In all honesty the 300I6 isn't far off those numbers.. 150hp @ 3400rpm and 260 ftlbs @ 2000rpm as dilivered. Add a tri-Y header and it'll produce well over 300 ft lbs, you may change your mind about the diesel swap after you drive it.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #10 (permalink)
Old 07-05-2009, 12:39 AM
trvcampbe trvcampbe is offline
trvcampbe is starting off with a positive reputation.
The 300 has been around for years "Tried and Trued"..It has a lot of torque.I guese it would depend on the work load applied.If you were going to use a 07 ranger for the same work load , then stay with the 300.That has a mazda tranny in it,drain the fluid and put synthetic tranny fluid..My opion,anyways..
  #11 (permalink)
Old 07-05-2009, 01:35 AM
Not an 07 ranger, 93 f150. I know the L6 aren't that far off. but it's diesel, fuel comes from a deep fryer and is free. A lot less parts to worry about. Way better mileage. Can use the same tranny, motor mounts etc. very easy swap with more low end torque. should still be able to cruise 65-70 no problem since I have 3.55's in the diffs. Can put it in low range and crawl up the Hoover damn. I just realized I've already made up my mind.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
