Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 02:10 PM
cjstreich's Avatar
cjstreich cjstreich is offline
cjstreich is starting off with a positive reputation.
Power Locks dead
New to the forum, I own a '99 expy EB and none of my door locks work, FOB will arm the system but not lock locks, internal door switches do not lock or unlock and the pad on the drivers door will not lock/unlock. The weird thing about this is the interior lights come on when you hit the unlock button on the FOB or enter the code on the door, and they also go out when you hit lock on the FOB or the 7/8 0/9 combination to lock on the pad, I'm not sure if one or all of the relays are bad in the dash, all fuses check out that seem to have to do with the door locks, and all other electronics work fine, what am I missing?
  #2 (permalink)
Old 07-04-2009, 02:37 PM
bnovak bnovak is offline
bnovak is starting off with a positive reputation.
double Check fuse 3 in the power distribution box Should be a 15A.
There are 3 relays - diver, all and all unlock. Might want to probe the V-in side (Black wire w/ white stripe) going into all the relays and make sure there isn't a break between the fuse block and relays. Also, check the all black wire for continuity to ground. Other than those relays and fuse, there isn't anything except for switches and actuators, but it seems like you are getting nothing at all so I'd check power & gnd.
Could also try probing after the relays - have someone hold down the interior button and see if there is voltage showing up?
-BN
__________________
'98 EB Expedition
'08 Mazda MX-5 w/ Cosworth Supercharger
'69 Mach1 Mustang
'40 Chevy Pickup rust bucket project
'79 Wetbike * '94 Waveblaster raceboat
'01 Bluewater Skiboat
  #3 (permalink)
Old 07-04-2009, 03:57 PM
I just had another thought.
When you push the lock or unlock button on the door, do any of the lock actuators make noise?
I'm wondering if one of the switches shorted closed, and is keeping the actuators powered at all times. If you probe the wires on the output side of the relay, none of them should have power unless you are pushing one of the buttons. Make sense?
I know it sounds like a PITA, but I almost wonder if it is worth disconnecting all of the door switches and then testing them individually. If one is shorted closed, it would basically power the system all the time and wouldn't allow anything else to happen.
__________________
'98 EB Expedition
'69 Mach1 Mustang
  #4 (permalink)
Old 07-04-2009, 06:26 PM
cjstreich's Avatar
Broken wire somewhere between the fuse block and wear the wires split right before the relays. Connected a known good positive to it and they work just fine. Thanks for the insight, the break could be anywhere lol but at least I know the switches work. Thanks again.
  #5 (permalink)
Old 07-04-2009, 08:29 PM
glad that worked. Good luck with the fix.
__________________
'98 EB Expedition
'69 Mach1 Mustang
  #6 (permalink)
Old 07-08-2009, 12:59 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a good reputation on FTE. 1ATony has a good reputation on FTE.
Quote:
Welcome to FTE,glad to see you got it fixed.
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Out Our Ford Truck Parts
Tags
1997 , 97 , door , expedition , fob , ford , fuse , locks , part , power , relay , time , unlocklock , work , works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
