Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 01:39 PM
mchild mchild is offline
mchild is starting off with a positive reputation.
How much A/C oil
I have a 1995 Explorer that I am replacing the compressor, accumulator and orifice. The under hood sticker calls for 7 oz of oil in the system. The replacement compressor has a sticker stating it has 7 oz of oil.
The shop book states the old accumulator will have oil in it and it should be measured and that amount plus 2 oz should be added to the new accumulator.
Should I remove some of the oil from the new compressor and add it to the new accumulator or is having it all in the compressor acceptable on start up?
Thanks for any guidance.
  #2 (permalink)
Old 07-04-2009, 07:35 PM
lsrx101 lsrx101 is offline
lsrx101 has a good reputation on FTE. lsrx101 has a good reputation on FTE.
The best thing to do would be to solvent flush the condenser and evaporator and blow them dry. This would put the oil at a known quantity (0oz). Then add 7 oz of fresh oil. Back flushing the condenser is necessary anyway if you've had a compressor failure.
Your 95 uses a Parallel flow condenser which can't be reliably flushed. You should seriously consider replacing it if the old compressor grenaded.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #3 (permalink)
Old 07-05-2009, 07:20 AM
Thank you.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
