Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 01:36 PM
ToughNut's Avatar
ToughNut ToughNut is offline
ToughNut is starting off with a positive reputation.
Poly spacers!?
I am looking to find anyone that sells polyurethane round stock. I need to make 2 custom spacers for my front coil springs. I do not want to buy a $127 kit. I have still less than $500 into this B2... want to keep it that way.
__________________
1986 BroncoII 2.9 V6 w/ 5.0 Injectors, Cherry Bomb,
no cat, on 31x11.5x15's with 2.5" lift and 96 explorer
A4LD auto trans.
  #2 (permalink)
Old 07-04-2009, 10:00 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
Where are you shopping for spacers? I've seen them for much less. Might want to check JC Whitney and others thoroughly (last I recall, JC Whitney had spacers for ~$10 a piece). Another idea is to make your own spacers from the right size washers. Only thing you'll need to address is extending your bottom retainer bolts going that route.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #3 (permalink)
Old 07-05-2009, 03:01 AM
ToughNut's Avatar
good idea
I want to keep the weight off it. Hence the poly.. I'll check JCW .. thank you .. oh the studs long enough ... 3"
__________________
A4LD auto trans.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
