Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 01:20 PM
Hardcase_Ford Hardcase_Ford is offline
Hardcase_Ford is starting off with a positive reputation.
Rough idle after warming up?
I have an 86 2.9 that runs great at start up, but when it warms up it idles rough and wants to die at low speeds when under a slight load. I replaced both pumps last year and the pressure is good. I'm thinking about replacing plugs and wires anyway.
What would you all suggest?
  #2 (permalink)
Old 07-04-2009, 09:48 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
I would suggest pulling diagnostic codes first. Could be just a tune-up issue, could be more. You may have (a) malfunctioning sensor(s), ignition module problems, or it could be just as simple as a vacuum leak or the idle air control. The intake and IAC tend to get gunked up from the PCV, and the EGR is known to also be a problem spot. Could also be the MAP sensor, but could be related to a vacuum leak on that. Big thing to check is your codes and wiggle test all of your sensors and check your vacuum hoses. Another noted area of concern is the ground connections on the wiring harness and connections to/from the battery. These things are quirky when it comes to dirty ground / battery connections. Hope this helps.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #3 (permalink)
Old 07-05-2009, 08:22 AM
Thanks I'll pull the codes.
Tags
06 , 2004 , 29 , battery , bronco , engine , ford , idle , idles , ii , map , replacing , rough , startup , tacoma , toyota , truck , warming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
