Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 12:05 PM
ferret2 ferret2 is offline
ferret2 is starting off with a positive reputation.
Interior Light Kill Switch
The family is going on a long trip later this year and we'll be driving through the night while the kids sleep. My wife's minivan has a dash mount switch that selects between int lights on, on with door open, and off. I'd like to do the same thing with my X for things like fuel stops, etc when one of the adults has to hop out but not blast the kids with bright int lights. I'd also rather not do so with pulling fuses. Any ideas?
Thanks
Craig
__________________
2000 X Limited 7.3PSD 4x4
1993 Supercoupe
1951 F1
1952 F6
  #2 (permalink)
Old 07-04-2009, 01:13 PM
Mydiesel250's Avatar
Mydiesel250 Mydiesel250 is offline
Mydiesel250 is starting off with a positive reputation.
Id like to hear from the gurus as well. I just got back from a long trip through the night with a sick 1yr old and pee breaks woke her up everytime. Free bump
__________________
Steve
2000 Ford Excursion 7.3
  #3 (permalink)
Old 07-04-2009, 02:17 PM
Monsta's Avatar
Monsta Monsta is offline
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
Here ya go.
http://www.ford-trucks.com/forums/27...5-xlt-dsl.html
__________________
Ken
  #4 (permalink)
Old 07-04-2009, 06:20 PM
blowhole's Avatar
blowhole blowhole is offline
blowhole is starting off with a positive reputation.
Didn't read a definitive answer on either this thread or the link one, Monsta. But will this work on a 2005 Ex?? I would love to make this mod work correctly. The ability to turn off all dome lights at will would be great.
Please advise.
__________________
blowhole
[ 2005 Excursion - Eddie Bauer - 6.0L PS ] : Zoodad w/ Z-Plate : 4" MBRP TB Exhaust w/ 5" tip & No Cat : Thule Rack on stock rails : ISSPro Boost & Trans Temp & EGT : Fumoto Valve : Silverstar Lamps
  #5 (permalink)
Old 07-05-2009, 02:35 AM
wallz's Avatar
wallz wallz is offline
2002 Ford Excursion
wallz has a good reputation on FTE. wallz has a good reputation on FTE.
I think for the earlier years, 2000, 01 you will find the fix for the lights in the fuse compartment like in the thread. I have an 02, and found the wires behind the passenger kick panel. I would presume the 05 would be the same.
I added a small switch up in between the switches for the venting rear glass.
__________________
2002 Excursion, 4x4, V-10, some mods, and many more to dream about!
  #6 (permalink)
Old 07-06-2009, 10:54 AM
blowhole's Avatar
Thanks. Do you remember the color of the wire behind the passenger side kick panel? And why is such a wire behind a kick panel?
__________________
blowhole
  #7 (permalink)
Old 07-07-2009, 12:11 AM
wallz's Avatar
2002 Ford Excursion
The wire you want, or wires are black with blue tracer. I say wire or wires because some get the running board lights at the same time, and splice into both together. Mine are corroded and have not worked in some time, which is fine with me anyhow, so I spliced into one only. Which one of the two, I couldn't tell ya. I found out the hard way and did both and blew a fuse, that is how I singled it out and figured that my running board lights are shot.
Why all the wires in the passenger side? Well, they run all the bundles for the back of the X down the passenger side. In fact if you ever have pulled off the passenger side bottom pc, which you have to pull anyhow, you will see a few bundles of wires and the rear washer fluid hose. The wires are just easier to access behind the inside kick panel. Just pull off some tape from them until you find the ones ya want.
I pulled the header panel rite out and then drilled and mounted switch, ran all the wires under interior liner, down the pillar to the splices. Left enough wires to be able to pull down that middle panel to access things later on as well.
__________________
  #8 (permalink)
Old 07-07-2009, 12:27 AM
Hockeybandit16 Hockeybandit16 is offline
Hockeybandit16 is starting off with a positive reputation.
Ford did miss the boat on this...It's a safety thing too...much easier to see into a lit vehicle if someone has bad intents. Also, much harder to see out if your interior is on.
If I just hopped in,say in a supermarket parking lot, I want to be able to idle in park till I'm ready to go, with the interiors off at night.
Tags
f150 , ford , kill , switches
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
