Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 12:52 PM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is starting off with a positive reputation.
Performance 351w build
Well the machine shop that has my 85 351w blocks said that there was a small hole in the cylinder wall of piston # 8. I have no clue what happened there I have access to a 94 351w block and i think its a roller motor. will the Crane cam 444232 cam work with this block, or is there another one that will produce better numbers with this being a roller? What are the differences between a roller and a nonroller as far as performance wise?
For now, i have 1.7 rockers, GT40 heads, the crane cam and LTs that are going on this motor. Is there anything else I can do on the SD setup for more power without doing too much for the SD to handle?
__________________
Guzzy
1989 F250 Custom
33" TruXus Mud-terrains
7 mpg city/highway/with plow/without plow/muddin/2000 lbs in bed
In progress: 75 351w with crane 444232 cam, 1.7 rockers in GT40 heads and Flowtech LTs
  #2 (permalink)
Old 07-04-2009, 12:55 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Yes '94 block will be roller ready, but the Crane cam will also drop in no problem the bearing journals are the same. Have you already purchased the cam?
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #3 (permalink)
Old 07-04-2009, 12:58 PM
guitarnik's Avatar
guitarnik guitarnik is offline
1990 Ford F-250
guitarnik is starting off with a positive reputation.
unless you want to stroke it, it looks like youve got things covered.
__________________
90 f250 4x4 5-speed 351w headman LT's 33x12.5 coopers CHEVROLET-Cheap Hardly Efficient Virually Runs On Luck Every Time
  #4 (permalink)
Old 07-04-2009, 01:04 PM
BRay09's Avatar
I have the cam, yes, but if there is another one that has significantly better numbers i will go pick that one up, then i will just use the 444232 in my dads truck and throw on some shorties while im in there.
  #5 (permalink)
Old 07-04-2009, 01:08 PM
BRay09's Avatar
Quote:
Thats something i want to stay away from. those kits are pretty expensive. lol. Maybe down the road ill be looking into a mass air convo... not very soon though. I think ill be happy with this build.
  #6 (permalink)
Old 07-04-2009, 01:12 PM
Conanski's Avatar
1990 Ford F-150
With SD you won't get significantly better performance with a roller cam, and it'll cost you 3-4 times more for the cam and lifters.
__________________
Paul O
  #7 (permalink)
Old 07-04-2009, 01:21 PM
BRay09's Avatar
Quote:
So staying with the 444232 cam will be the best option? this donor is a 94 and its still SD... I really was hoping for it to be MA so i could take all the parts i needed for the later build, either for this motor, or my next one...
  #8 (permalink)
Old 07-04-2009, 01:28 PM
Conanski's Avatar
1990 Ford F-150
Thought you were just getting a block not a complete motor?
__________________
Paul O
  #9 (permalink)
Old 07-04-2009, 01:33 PM
BRay09's Avatar
I actually have access to the whole truck. Its my uncles i didnt know he had. he said i could have the whole thing for some work im doin for him. Its a 94 with a 351w and a bad E4OD...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
