Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 12:15 PM
ranger982 ranger982 is offline
1974 Ford F-250
My Garage
ranger982 is starting off with a positive reputation.
Truck will hardly even idle!!!
got a F350 flatbed with a 351M its a 1980 but i figure the 73 to 79 forum would be more knowldgeable on this engine. It used to start and idle good, now it hardly idles. at any little bit of throttle you could hear the butterfly's open the air hiss as it promptly stall's, checked the timing chain it was good, it has almost 15 inches of vaccum and is steady, the distributer is on time at 10'BTC i am having trouble now getting my timing light to pick-up, i tried changing out my coil ( i had a msd blaster 3 i threw on it) didn't change it at all. I'm trying not to spend alot of money on this thing but i would like to have it running it makes a great around the barn yard truck!!! i know i'm probably overlooking the odvious so any help is appreciated... Thank you very much.
  #2 (permalink)
Old 07-04-2009, 12:23 PM
montana_highboy's Avatar
montana_highboy montana_highboy is offline
montana_highboy is gaining momentum as a positive member of FTE.
fuel filter? accelerater pump? is fuel pump pushing enough fuel at idle?
__________________
75 Highboy 390 4spd
  #3 (permalink)
Old 07-04-2009, 12:32 PM
1974 Ford F-250
My Garage
new fuel pump, filter is new, rebuilt carb
  #4 (permalink)
Old 07-04-2009, 12:33 PM
1974 Ford F-250
My Garage
new fuel lines
  #5 (permalink)
Old 07-04-2009, 01:21 PM
bigdavesohc's Avatar
bigdavesohc bigdavesohc is offline
bigdavesohc is starting off with a positive reputation.
Last time that happened to me, it turned out the gas tank was the problem. It was corroded so bad it would clog the fuel filter in a matter of hours.
__________________
1976 F250 Highboy 4X4
390/4Speed~NP205/D44/D60
31" Maxxis Buckshots
  #6 (permalink)
Old 07-04-2009, 01:37 PM
1974 Ford F-250
My Garage
well it runs off a boat tank, i had i nice hole in my tank, and the advance in the distributer works too.
  #7 (permalink)
Old 07-04-2009, 01:49 PM
76f350spercamprspeal's Avatar
76f350spercamprspeal 76f350spercamprspeal is offline
1976 Ford F-350
My Garage
76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE.
You could have a manifold vacuum leak.
Check the the vacuum line going to the brake booster and other vacuum lines which would keep it running and idling smoothly.
Maybe your truck is starved for fuel.
__________________
-With all Due Respect-
--Anthony-- -*~<-76SCS->~*-
*Anthony's Truck Pictures *Anthony's Truck Pictures-2 *Anthony's Truck Pictures-3
Father's Formally owned-67 F250-69 F250-77 F350-93 E350-*--Join The SoCal Chapter *Here*
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
