Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 12:05 PM
Goto Goto is offline
Goto is starting off with a positive reputation.
Radiator Fluid
I have a 2008 F350 with the 6.4L diesel, with 20,000 miles. I just got back from a camping trip this week and noticed the next morning that I had a puddle of radiator fluid under the front bumper on the passenger side. The engine never ran hot but on inspection I found the reservoir was empty. With all the radiators up front it is nearly impossible to see where it is coming from. Does anybody have any ideas what the problem may be?
Goto
  #2 (permalink)
Old 07-04-2009, 12:11 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
It could be anything from a loose clamp to a bad hose or cap to a leaking core. Since it didn't run hot, it shouldn't have much of a pressure leak. A slight pressure is required in the coolant system, usually 13-18psi. To drain the res, any leak would have to be below it, so we can rule out the cap. I would look for damage or evidence of critters first, something that could have happened close to home.
Welcome to the forums.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 07-04-2009, 01:27 PM
John7894's Avatar
John7894 John7894 is offline
John7894 is starting off with a positive reputation.
Also, check the 6.4 forum. There have been problems with the radiators leaking on the new 6.4s. Most all have been covered under warranty if caught soon enough.
__________________
John
2008 F350, 6.4, Crew Cab, King Ranch, 4WD, SRW, 62,000 miles.
2001 F250, 7.3, Crew Cab, Lariat, 2WD. 329,000 miles and counting!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
