Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 10:31 AM
pacrewchief pacrewchief is offline
pacrewchief is starting off with a positive reputation.
Need Help with this one.
I am working on a 1995 F-350 4WD Dually Diesel. I replaced all of the brake hoses and steel lines, new calipers, pads, rear drums, shoes and wheel cylinders and a new master cylinder. Bled the brakes and got all the air out. When you start the motor the brake pedal goes right to the floor. Motor not running works as it should, motor running pedal goes right to the floor. I have already changed the master for another new one. Any ideas as to what I am missing? Appreciate your help.
  #2 (permalink)
Old 07-04-2009, 10:49 AM
guitarnik's Avatar
guitarnik guitarnik is offline
1990 Ford F-250
guitarnik is starting off with a positive reputation.
did you adjust your rear shoes out to where they just barely rub? what about the booster?
__________________
90 f250 4x4 5-speed 351w headman LT's 33x12.5 coopers CHEVROLET-Cheap Hardly Efficient Virually Runs On Luck Every Time
  #3 (permalink)
Old 07-04-2009, 10:57 AM
Yes, rear shoes barely rub, the booster works it provides assistance and holds vacuum as it should.
  #4 (permalink)
Old 07-04-2009, 11:05 AM
frankyford frankyford is offline
frankyford is starting off with a positive reputation.
Bleed them again and make sure you got brake fluid going into the lines . When you pump them up do they get hard and then go to the floor or do they not get hard at all. If they do not get hard you're getting air into the line somewhere and I would really examine the master cylinder and the lines going in. It may not have gotten a good enough prime. The same thing happen to my 81 F-100
__________________
Frank
Stockbridge, Ga
  #5 (permalink)
Old 07-04-2009, 11:52 AM
lvmadsigntist lvmadsigntist is offline
lvmadsigntist is starting off with a positive reputation.
Don't knnow if this will help, many years ago a friend of mine did a brake job on his f-100 and had the same problem. I took the front wheels off and discovered the calipers were on upside down, the bleeder was on the bottom instead of the top. He had switched the two sides. He could bleed and get fluid but since the bleeder was not on top he couldn't get all of the air out.
  #6 (permalink)
Old 07-04-2009, 12:58 PM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE.
You still have air in the lines. Have a look on the inside of the left side frame rail for the RABS module (if fitted) and bleed that after the rear brakes. It`s about level with the brake pedal.
  #7 (permalink)
Old 07-04-2009, 01:01 PM
guitarnik's Avatar
1990 Ford F-250
the RABS is right below the master cyl on the drivers side frame. also if you take your master cyl off is there fluid leaking past the diaphram/plunger
__________________
  #8 (permalink)
Old 07-04-2009, 02:05 PM
I had the same thought but could'nt remember what to call it, he may not have punched through it all the way.
__________________
Frank
Stockbridge, Ga
  #9 (permalink)
Old 07-04-2009, 02:28 PM
leesflare leesflare is offline
leesflare is starting off with a positive reputation.
Was the master cylinder bench bled before installation?
  #10 (permalink)
Old 07-04-2009, 03:13 PM
Yes the master cylinder was bench bled and the RABS valve is bypassed. By that I mean the rear brake line runs from the rear axle to the master cylinder. This is an old township truck...think salt and corrosion!! That is why everything needed replaced. Thank for the replies!!! This has me completely befuddled.
  #11 (permalink)
Old 07-04-2009, 03:25 PM
OK, now don't get upset here folks, I'm a Toyota tech for a new car dealership. On some of the older cars, we experience a similar situation when the caliper sliders stick. Pump all day long with good fluid flow and a hard pedal, but start the engine and pedal is on the floor. Took a long time to figure that one out.
Lee
  #12 (permalink)
Old 07-04-2009, 03:37 PM
Good thought, I checked that. The pads are clamped to the rotors just like they are supposed to be. Thanks!!
  #13 (permalink)
Old 07-04-2009, 03:41 PM
Not sound like an idiot, but maybe bypassing it is what is causing it, that a long way for the fluid to travel without still having air in it.
__________________
Frank
Stockbridge, Ga
  #14 (permalink)
Old 07-04-2009, 03:55 PM
Popa Tim Popa Tim is offline
Popa Tim is starting off with a positive reputation.
You need a different MC if you bypass the rabs. RABS works by bypassing fluid pressure back to the resevoir. 1 line from the res in an input and the other the output. You are basically dumping your high pressure fluid right back into the res.
Well at least thats my understanding of how our RABS works. Try using an MC from something like a 70's truck.
__________________
F150 XLT 4x4 5.0 E4OD Supercab Shortbed
  #15 (permalink)
Old 07-04-2009, 04:08 PM
Jeff Dodson's Avatar
Jeff Dodson Jeff Dodson is offline
Jeff Dodson is starting off with a positive reputation.
Just get a MC from and F450. I had to do that on my 91 Diesel F250. There was actually a service bulitin about it, that was the repair. Now the two mounting holes where it mounts to the brake booster, you have to elongate the mounting holes in the MC to fit, but all else is a direct bolt.
__________________
1997 Ford F250 4x4
2001 Mustang Bullitt
2003 Harley Davidson RoadKing ( POLICE )
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
