Really am curious. Mine seems to Idle fine, but seems rough when I first start it up. Oil pressure gauge says low for a second.
I believe the gauge reads the HPOP?
I had reading issues on it, and cleaned the HPOP sensor connection, and it works fine now. Oil drain down on the HPOP?
I haven't really much paid attention to other peoples PSD's when around them, cause they were not running, but the reason I ask the rough idle is because mine has the Rock.
I do like it rocking back and fourth, which is kinda cool, but if its not supposed to be, then I should fix it. hah!
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Head over to www.midnightmods.com to see some of my projects.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
Older engines will do that, rough idle cold them straighten out with a little warmth.
If it's "romping after it up to temp you may have issues.
Try shifting the trans into N to see if it changes. A TRS out of adjustment can cause the romps.
No worry as long as it starts good. You can address it next time the VC come off. if the TRS is OK.
The oil pressure gage is on the HPOP but it measures the LPOP pressure.
It would be nice to have an permanent HPOP gauge but expensive. They use a sending unit.
I have a 4000psi gauge for temporary tests but it's mechanical. There is no way i would bring that much oil pressure inside the cab. Messy & dangerous IMO!
__________________ Horsepower = How fast you hit the wall. Torque = How far you take the wall with you.
They say if you play a Microsoft CD backwards you hear scary messages.
Even scarier......if you play it forwards it installs Windows
Started good today. Sometimes it stutters a second when starting and evens out immediately.
__________________
__________________
TRS = Transmission Range Selector E4OD has a sensor/ switch that atcuates the transmission into gear from the column vs a physical connection like the old c6 or something of that nature.
__________________
Romping is when the motor acts like it wants to cut out when cold idling... very distinctive once you've heard it. Idles up, almost dies, rinse and repeat a few times very quickly. Usually only an issue in cold weather. The motor rocking at idle is normal, throw a Riffraff HPX on there and it will smooth out a ton.
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2 God speed Markadeck, you will be missed ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
__________________
Mine does that when the motor is warmed up... what is a HPX?
__________________
1997 F250 PSD 4x4 5 Speed: 6637 Intake, ISSPRO Boost and Pryo, 315/75/16 A/Ts, AB 130cc Injectors
1996 Mustang GT: with a 351 swap with Stalled C4 (Race Car) 10.76@122 with a 1.52 60'
1999 28' Classic Dominator (Race Car Hauler)
"just cause its smoking, don't mean its broken"
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
