Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 09:42 AM
WJC WJC is offline
WJC is starting off with a positive reputation.
Hypertech
I have read an artical in diesel mag regarding engine problems with the 6.0 powerstroke. They pointed out a problem with the piston cracking when a guy drove his truck everday on race tune. I'm not here to knock the 6.0, actually wish i had one in my ex, but i do have a hypertech in my 6.8. Will this cause any problems with everyday driving or should i set it back to factory spec? I am running it on 87 octane fuel and do have it set for trans firmness. I don't drive it hard at all.
__________________
2005 EXCURSION LIMITED 4X4 6.8 V10 K&N FIPK GIBSON EXHAUST Y-PIPE HYPERTECH MAX ENERGY PIONEER NAVIGATION AVIC Z-1 POWER SLOT CYRO ROTORS KOOLVUE MIRRORS CATCH ALL MATS MOBILE-1 37,000 MILES
  #2 (permalink)
Old 07-04-2009, 12:33 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
In short no.
Hypertech built in tunes are designed to be safe for all the vehicles they cover. There is still plenty of headroom/safety built in. As long as you feed it the right fuel in, temps will be consistent and acceptable for the pistons and heads.
The trans firmness shouldn't set to max though. Bumping up the line pressure is hard on the pump and is suspected to cause premature failure. Maybe setting at 3/4 max or below would be fine.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 07-04-2009, 01:35 PM
gr8scott72 gr8scott72 is offline
gr8scott72 is gaining momentum as a positive member of FTE.
I would think that really the only thing a programer could do to harm a gas engine would be to have the timing advanced too far causing pinging/detonation.
I quit using a programer for that very reason on my Durango as it would ping under load with the programer (even on the 87 octane setting) and I didn't want to feed it higher octane fuel.
__________________
Scott
2000 Excursion XLT 4x4 V10 4.30, Powerslot slotted rotors w/ Hawk SuperDuty pads up front, Hawk SuperDuty pads on the rear stock rotors, Roadmaster Active Suspension, Optima Red Top Battery, backup camera, Tom Tom XL100 GPS
  #4 (permalink)
Old 07-04-2009, 06:35 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
2001 Ford Excursion
Toreador_Diesel has a good reputation on FTE. Toreador_Diesel has a good reputation on FTE.
As far as trans firmness, I would go with a TransGo Tugger shift kit or the Sonnax/Tricumulator kit that I got. The same applies with your trans as with computers, hardware is always better than software.
The programmer will help with power and fuel economy but not as much as if it were a diesel. To me, I think it's worth it if I get a better performing engine out of it, but then again that's up to you.
As far as that guy in his 6.0, he obviously doesn't know anything about mods and preparing your truck for the added power. If you do the research and read the warnings on the box and in the manual, a race tune is NOT for everyday driving. It's as it's name implies: for Racing Only!
__________________
If you live in Texas and need help with your truck, PM me.
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
Tags
kit , sonnaxtricumulator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
