Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 07:41 AM
Blue80's Avatar
Blue80 Blue80 is offline
Blue80 is starting off with a positive reputation.
351W Timing marks & 408 clearance question
Hey Ford guys, I'm a chevy guy helping my Brother-n-law build a 408w. We are using a Cloyes True roller timing set and there is no defined timing mark (dimple) on the crank gear. There is the 3 key way locations for cam timing and I'm putting the cam in at zero. I’m assuming that the key way “O” is the crank gear timing mark that should be at 12’ 0 clock and the cam gear dimple is at 6’O clock.
We are building a 408w (eagle crank, eagle h rods, probe pistons) with AFR 185 heads. Are there any rotating assembly clearance issues that need to be checked (rod to cam, etc)?
  #2 (permalink)
Old 07-06-2009, 11:28 PM
393STROKER's Avatar
393STROKER 393STROKER is offline
393STROKER is starting off with a positive reputation.
When I had the 393 w/Eagle crank built they said they had to clearance the rod bolts for the roller cam.The rod bearings that came w/it did not fit the crank fillets so we had to use narrower race bearings and they re-balanced the rotating assembly.
  #3 (permalink)
Old 07-08-2009, 01:01 PM
Blue80's Avatar
Thanks 393. My brother in law was helping me build my 408. It all went well.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
