Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-06-2009, 11:14 PM
Bovaloe Bovaloe is offline
1991 Ford F-150
Bovaloe is starting off with a positive reputation.
Quote:
Originally Posted by trvcampbe View Post
You can blow through it?
Yup you sure can
  #17 (permalink)
Old 07-07-2009, 02:53 PM
1991 Ford F-150
Still having trouble, running out of ideas. Anyone got any fresh ones for me?
  #18 (permalink)
Old 07-07-2009, 02:57 PM
andym's Avatar
andym andym is online now
1989 Ford F-150
My Garage
andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future
The codes point to an EGR problem, which is unrelated to the oil coming out the breather. If the PCV valve is clear then I would do that compression check you mentioned. Sounds like you might have some pretty serious blow-by.
__________________
Andy
Quote:
Nothing is obscene if we only close our eyes
  #19 (permalink)
Old 07-07-2009, 07:37 PM
1991 Ford F-150
Well finally had a day off so I did a compression check, dont really like what I found but here it is.
#1-180 #5-195
#2-0 #6-193
#3-190 #7-193
#4-185 #8-202
Next move? pulling cylinder head off?
  #20 (permalink)
Old 07-07-2009, 10:38 PM
393STROKER's Avatar
393STROKER 393STROKER is online now
393STROKER is starting off with a positive reputation.
I had a van that was blowing oil out the dipstick tube once. Same as you I was going to work and it just started running bad.Found that one of the pistons had a hole melted in it,probably because the day before I put smaller jets in the carb to save on gas and it was running way to lean.
  #21 (permalink)
Old 07-07-2009, 10:53 PM
BucksTrucks's Avatar
BucksTrucks BucksTrucks is offline
BucksTrucks is starting off with a positive reputation.
That would be the next thing to do... My truck has been having the same problem minus the egr codes. I was getting cross firing from the 7-8, and some real light pinging pulling up big hills. Truck lost power on I-5 popped the hood at jack in the box, and the breather was blowing oil all over hell. Checked PVC and it all was sat. Drove it 80 miles home to play with it, misfiring and shaking the whole way. Was playing with it last night, all the plugs looked good but #8, it was black and sooty. Checked spark on that cyl and moved the plug wire way outside, around the dip stick even. Power is back, 80% of the mis fire is gone, but its still has some missing around 1000 rpm and still blows oil.
__________________
1991 F150 133'' 4x4, 4.10, 5.8L crane 444232 cam, summit shorty headers, magna flow muffler. Dick Cepek Stage 2 lift, Bilstien 5150 10'' travel shocks, Sky shackle flip, 32x11.50 BGF M/Ts.
  #22 (permalink)
Old 07-08-2009, 12:19 PM
andym's Avatar
1989 Ford F-150
My Garage
Yeah, that doesn't look good at all. Let us know what you find with that dead cylinder. With any luck it's a bent valve, but you normally don't get oil in the breather that way.
__________________
Andy
  #23 (permalink)
Old 07-12-2009, 02:08 PM
1991 Ford F-150
Got the head off finally, and theres a hole in the piston.
I figured it was time to upgrade a bit so Im thinking on ordering a 347 long block crate to throw in. Any suggestions on where to get it?
Also has anyone done this? What sort of hang ups could I run into when Putting this sucker in?
Tags
1990 , 49 , f150 , hose , pcv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
