Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 03:57 AM
Rizzo66_82 Rizzo66_82 is offline
Rizzo66_82 is starting off with a positive reputation.
loss of power / wont start
I have an 04 Superduty bone stock no lift, no programmer, not even exhaust, about a month ago getting on the freeway my truck stumbled and died on the onramp. I waited a couple of minutes and restarted the truck got on the freeway and there the truck died again. got it to a shop they worked on it for two days, found no problem/ no codes/ pulled the FICM out/ it was good and checked the harness/ no visable wear... so they put the truck together and it started fine drove fine, they fixed nothing except to zip tie around the FICM plugs incase they were falling out. now today having driven the truck longer then any other day since the last breakdown I had the same problem/ about 40 mins prior to the break down the pump directly below the drivers seat on the frame rail ( no sure what it is - i know the primary filter is there) started making a loud noise that would come and go intermittintly. the FICM plugs are still tight and in place. i popped the secondary fuel filter cap and there was no fuel in the bowl no matter how mny times i cycled the key/ both days the temp was in the mid to high eightys.... any ideas????
  #2 (permalink)
Old 07-04-2009, 05:02 AM
bismic's Avatar
bismic bismic is online now
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
The frame rail filter / pump is called the HFCM - Horizontal Fuel Conditioning Module. Sounds like it needs to be replaced. It is a fairly easy job if you want to tackle it yourself. You can look for the replacement HFCM at the sources below:
Cheap OEM Parts
http://www.discountfordpartsaty2kford.com/
http://ad.doubleclick.net/click%3Bh=v8/381a/3/0/%2a/p%3B212209167%3B0-0%3B1%3B22973165%3B1355-2/2%3B30306852/30324729/1%3B%3B~sscs%3D%3fhttp://www.trademotion.com/partlocator/index.cfm?siteid=215005
http://www.newfordparts.com/
http://www.directfordparts.com/partlocator/index.cfm?siteid=214290
http://fullerfordparts.com/default.aspx
http://usdieselparts.com/category.cfm?category=143
http://stillen.com/
http://www.car-parts.com/
http://www.powerstrokeshop.com/
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #3 (permalink)
Old 07-04-2009, 10:31 AM
so is that HFCM the low pressure fuel pump?
  #4 (permalink)
Old 07-04-2009, 11:19 AM
bismic's Avatar
The injectors are actuated by high pressure oil (HYDRAULIC ELECTRONIC UNIT INJECTOR: HEUI fuel system) and an intensifier piston in the injectors. You have two oil pumps but only one fuel pump.
__________________
Mark
  #5 (permalink)
Old 07-05-2009, 08:07 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is online now
Farmer and proud of it
bigredtruckmi is gaining momentum as a positive member of FTE. bigredtruckmi is gaining momentum as a positive member of FTE.
On the easy side...... When was the last fuel filters change?? Might want to change in case you got some bad/dirty fuel on the road. This would cause fuel starvation of the engine. Fuel filters should be changed every other oil change.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #6 (permalink)
Old 07-06-2009, 09:37 AM
I changed the fuel filters about 4000 miles ago
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
