Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 02:48 AM
DasCheckers's Avatar
DasCheckers DasCheckers is offline
Montana, fool.
1993 Ford F-150
DasCheckers has a good reputation on FTE. DasCheckers has a good reputation on FTE.
What mods do you think are HP gaining myths? (Research for Testing)
Ok, so as a dude with tons of mechanical knowledge and unlimited access to a 4-wheel dyno, I'd like to compile a list of theories, parts, and mods that you personally think will increase horsepower and torque.
They will all be tested througholy, and results will be posted.
For example,
Throttle Body Spacers
The Infamous Smog Pump Super-Charger
Cold Air Intake
Different Stock Snorkels from different motors
Custom, ARB type snorkel
EGR Delete
Smog Pump Delete
A/C Delete
Electric fan conversion
Headers
Straight pipe
Gutted cat
Higher Octane Gas
Advanced timing
What are your ideas on increasing horsepower?
Shoot me your ideas and things you've heard about!
__________________
Stoney | Montana Chapter Leader of FTE
Live in Montana? Come join The Montana Chapter,
1993 Ford F150 XLT 4x4 5.0 5spd with a Fresh Rebuild
Write your congressman!
  #2 (permalink)
Old 07-04-2009, 03:09 AM
cchimuk cchimuk is offline
cchimuk is starting off with a positive reputation.
Have you considered under-drive pully's as well for your test run.
  #3 (permalink)
Old 07-04-2009, 10:31 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
How about testing the Explorer and HO intakes against the truck intake?
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #4 (permalink)
Old 07-04-2009, 10:47 AM
guitarnik's Avatar
guitarnik guitarnik is offline
1990 Ford F-250
guitarnik is starting off with a positive reputation.
headers....LT against ST
__________________
90 f250 4x4 5-speed 351w headman LT's 33x12.5 coopers CHEVROLET-Cheap Hardly Efficient Virually Runs On Luck Every Time
  #5 (permalink)
Old 07-04-2009, 11:01 AM
Montana, fool.
1993 Ford F-150
All great ideas! Keep 'em coming.
I'm going to buy a few parts but I might just pay some shipping charges and borrow some parts from you guys too.
Post up if you have something you would be willing to test!
Everyones ideas will be tested!
__________________
  #6 (permalink)
Old 07-04-2009, 11:46 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
For example,
Throttle Body Spacers // dont waste your time
The Infamous Smog Pump Super-Charger // Waste of time
Cold Air Intake // 5-10 hp
Custom, ARB type snorkel //no hp increase
EGR Delete //waste of time
Smog Pump Delete // less drag
A/C Delete // only when it is on is it robbing power
Electric fan conversion // less drag
Headers // more torque
Straight pipe // Only on high rpm race engines
Gutted cat // reduced power
Higher Octane Gas // depends on the app
Advanced timing // yes
All these topics have bee gone thru already
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #7 (permalink)
Old 07-04-2009, 01:37 PM
alxsnmr alxsnmr is offline
1991 Ford Bronco
alxsnmr is gaining momentum as a positive member of FTE.
How about pitting a 460 against the 5.4 like another thread in somewhere else in this website fought over. Then pitting the V-10 against the 7.3L turbo of late vintage.
Oh wait those arent horsepower mods.
See if the racing stickers help
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
  #8 (permalink)
Old 07-04-2009, 02:27 PM
93 mix 'n match's Avatar
93 mix 'n match 93 mix 'n match is offline
NJ Chapter
1993 Ford F-150
93 mix 'n match is gaining momentum as a positive member of FTE.
my predictions. and some of them i know for a fact.
Throttle Body Spacers-no
The Infamous Smog Pump Super-Charger-no
Cold Air Intake-yes
Different Stock Snorkels from different motors-no
Custom, ARB type snorkel-maybe
EGR Delete-yes
Smog Pump Delete-yes
A/C Delete-yes
Electric fan conversion-yes
Headers-yes
Straight pipe-yes
Gutted cat-maybe
Higher Octane Gas-duh
Advanced timing- retard over stock, not advance.
__________________
What would Jesus do for a Klondike bar?
Not in current ownership of a ford vehicle.......
  #9 (permalink)
Old 07-04-2009, 03:09 PM
70torino429's Avatar
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
hmm, i could go on for days about the myths. Such as heads with big ports wont make torque.
But as far as the everyday mods, i think you got them covered.
Id like to see dyno results on a smog pump supercharger, as crazy as the idea may be, dyno results can put that one to rest or bring it to life.
__________________
  #10 (permalink)
Old 07-04-2009, 03:42 PM
Popa Tim Popa Tim is offline
Popa Tim is starting off with a positive reputation.
How about the old school alternator kill switch. A switch that cuts the voltage to the alternator, preventing it from creating the magnetic field thereby allowing it to freespin instead of parasitically draining a few HP.
__________________
F150 XLT 4x4 5.0 E4OD Supercab Shortbed
  #11 (permalink)
Old 07-04-2009, 04:32 PM
lew52's Avatar
lew52 lew52 is offline
lew52 is gaining momentum as a positive member of FTE.
Stock thermosate VS 160 thermostate ... & Mix 'n match why do you say retard the timing instead of advance , just wounder what the reasoning is ?? Lew
  #12 (permalink)
Old 07-04-2009, 06:15 PM
Montana, fool.
1993 Ford F-150
Quote:
But none have had actual thorough testing performed.
Which will be the point behind this testing.
No one ever posts factual evidence.
More great ideas guys! MORE IDEAS!
Anything you've ever wondered?
Even if it's odd, I'm up for it!
__________________
  #13 (permalink)
Old 07-04-2009, 06:31 PM
NJ Chapter
1993 Ford F-150
Quote:
i might have it backards. the point is to make the plug fire before the piston hits the top. this way it has time to burn all the way before it starts to push the cylinder down.
example. my fathers old chevy 6 cylinder. the timing was 4 before TDC. he retarded it to 6 and got noticeably more power and better mileage. this of course was a while ago and is for lower octane fuel that dosent combust as fast as higer octane fuel.
__________________
  #14 (permalink)
Old 07-04-2009, 06:58 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
1994 Ford Mustang
My Garage
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
That is advancing the timing.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
http://mistercmk.com/images/sig.jpg
Quote:
Originally Posted by tcbofade
I have no brain
  #15 (permalink)
Old 07-04-2009, 07:04 PM
NJ Chapter
1993 Ford F-150
Quote:
its making it fire earlier.....you sure its "advancing"? im no certified mechanic but.....
then again.....your probably right.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
