Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 07-06-2009, 10:18 PM
393STROKER's Avatar
393STROKER 393STROKER is offline
393STROKER is starting off with a positive reputation.
You guys got me thinking so I looked up stuff about gasoline,and octane ratings and found that higher octane gas is only good if your engine requires it and is a waste of $ if it doesn`t. I looked up -What octane rating of gasoline should I use - and part of it says that all gas has the same burn rate, and part of it says that higher octane burns slower.I used race gas from the pump @ the track once and it made no difference.
  #47 (permalink)
Old 07-08-2009, 11:20 AM
Neptoess Neptoess is offline
Neptoess is starting off with a positive reputation.
the 4.9L Cadillac V8(preNorthstar) in my buddy's 95 deville "requires" 92 octane but I told him he could safely run 87 as it would retard the timing to compensate, but it does have a 9.5:1 compression, and that car ****in moves. More hp and torque than my 302 and it's in a car . He wasn't convinced though, and continues to run 92....
__________________
1995 F-150 EB 302/4R70W rc lb 2wd 3.55s
-Sony Head Unit controlling 30 GB iPod
-Kenwood KAC-6202 200W RMS@2 Ohms into:
-Polk Audio 55W 6.5" front speakers
-Pioneer 50W 6x8 rears
-Kenwood KAC-6104D 300W RMS@2 Ohms into:
-Alpine Type S 10" Subwoofer mounted behind drivers seat
  #48 (permalink)
Old 07-08-2009, 11:24 AM
393Stroker. The reason race gas made no difference is because you most likely didn't change anything with your engine. Race gas is for people with high boost, high compression, advanced timing, etc. This is because lower octane fuels will ignite before the spark comes from the amount of heat and compression inside the cylinder, which is called detonation. It causes pinging and is really bad for your engine. Race gas is also for people with too much money, like my mom's boss who drives his lotus elise around town with 92 in it and has no problems but thinks the 110 he puts in at the track is giving him a performance boost.
__________________
  #49 (permalink)
Old 07-08-2009, 11:32 AM
lew52's Avatar
lew52 lew52 is online now
lew52 is gaining momentum as a positive member of FTE.
It all depends how your car or truck is tuned , most hi performance (built) motors are tuned for higher octane fuel so they can use a more aggressive timing curve... Lew
  #50 (permalink)
Old 07-08-2009, 08:05 PM
guitarnik's Avatar
guitarnik guitarnik is offline
1990 Ford F-250
guitarnik is starting off with a positive reputation.
higher octane fuel doesnt burn faster or slower it is actually less "burnable" if thats what you want to say. that why higher compression engines run it. because of the extra pressure it ignites as well as lower octane fuel will with a much lower compression ratio.
__________________
90 f250 4x4 5-speed 351w headman LT's 33x12.5 coopers CHEVROLET-Cheap Hardly Efficient Virually Runs On Luck Every Time
  #51 (permalink)
Old 07-08-2009, 08:33 PM
Jeff Dodson's Avatar
Jeff Dodson Jeff Dodson is offline
Jeff Dodson is starting off with a positive reputation.
Quote:
Originally Posted by deeznuts822 View Post
Disconnecting the heater hose that goes to the throttle body. Thus a colder throttle body and intake
I have a 97 f250, 351W, does my truck have the heater hose going through the throttle body. I will have to look, I would get rid of that anyway, beings we have 800* weather here in South Texas, MAN ITS HOT
__________________
1997 Ford F250 4x4
2001 Mustang Bullitt
2003 Harley Davidson RoadKing ( POLICE )
  #52 (permalink)
Old 07-08-2009, 08:37 PM
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
Quote:
my northstar 4.6 caddy said the same thing, but the electronics on those cars allow you to run less octane gas. It sure liked when you put 93 in it though, but the northstar had a bit higher 10:1 compression. My experience has been that it runs a little better on 92-93 octane but wasnt completely necessary, both the 4.9 and 4.6 dohc northstar do indeed haul ass.
__________________
  #53 (permalink)
Old 07-08-2009, 08:46 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
So Das.. when can we expect to see some dyno results?
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #54 (permalink)
Old 07-08-2009, 10:33 PM
DasCheckers's Avatar
DasCheckers DasCheckers is offline
Montana, fool.
1993 Ford F-150
DasCheckers has a good reputation on FTE. DasCheckers has a good reputation on FTE.
Quote:
Well, I need some time to gather parts for all of those tests.
Hopefully people will step up and ship me some parts to borrow for testing.
I'm busy as anything until about August 1st or so but after that I should have time.
I'll start with the simple mods that anyone can do.
All testing will be done on my freshly rebuilt 5.0 that is bored .20 over.
All results will be posted in percentage form.
For example, CAI added "0.04" of total power.
I'll compile a list and post it here to make sure I'm including everyone!
__________________
Stoney | Montana Chapter Leader of FTE
Live in Montana? Come join The Montana Chapter,
1993 Ford F150 XLT 4x4 5.0 5spd with a Fresh Rebuild
Write your congressman!
  #55 (permalink)
Old 07-08-2009, 11:53 PM
Quote:
yeah he let me drive it. sloppy steering and the shifter moved freely without being pulled back(not so luxury imo) but i put it down on a straightaway and im used to my 5.0 with 39k that 4.9 with 132k snapped my neck and zoomed. Computer controlled suspension felt like i was floating above the road. Then the road turned and i had to slow down bc of the sloppy gpa steering. FWD and it's looser than my RWD F150, cmon caddy wtf lol
__________________
  #56 (permalink)
Old 07-09-2009, 12:05 AM
Old93junk's Avatar
Old93junk Old93junk is offline
Old and mean
1993 Ford F-250
Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold
And Cadillac says its "within specifications" for the Northstar V8 to burn a qt. of oil in 500 miles..........Uh, my 460s oil level never goes below full in 3,000 miles!
__________________
FORCE IT!,IF IT BREAKS IT NEEDED REPLACED ANYWAY!
IF IT CANT BE FIXED WITH A HAMMER, ITS A ELECTRICAL PROBLEM!
Still bitterly clinging to guns and religion.
Dave
Oregon Assistant Chapter Leader: To join the Oregon Chapter, click HERE
  #57 (permalink)
Old 07-09-2009, 12:12 AM
that's worse than dodge. dealers were getting customers who had intrepids burning oil so to avoid fixing it dodge released a tsb saying it's normal to burn 1 qt every 1000 miles. In a motor that holds 4 qts that leaves you putting 7 qts in every 3000 miles. Normal? Maybe for a dodge owner, but not for me
__________________
  #58 (permalink)
Old 07-09-2009, 12:13 AM
some engines do burn oil though if they're high compression or run really hard, depending on what kind of oil you use. Cheap oil in an engine that's driven hard will break down and burn off far before 3000 miles. That's why we pay 5 dollars extra for synthetic . That and valvoline is supposedly guaranteeing my engine to 300k if i run their synthetics in it, so that helps too lol
__________________
  #59 (permalink)
Old 07-09-2009, 12:17 AM
Old93junk's Avatar
Old and mean
1993 Ford F-250
not as bad as dodge. dealers were getting customers who had intrepids burning oil so to avoid fixing it dodge released a tsb saying it's normal to burn 1 qt every 1000 miles. In a motor that holds 4 qts that leaves you putting 7 qts in every 3000 miles. Normal? Maybe for a dodge owner, but not for me
Put that on a dyno!...............Probably a mopar performance feature.....extra top end lubrication!
Any more oil consumption than that and you would have to call it a 2 stroke!
__________________
Dave
  #60 (permalink)
Old 07-09-2009, 12:29 AM
well at least now no one will argue with me. the dodge fans hated knowing that my 95 f150 with a 302 and 3.55s has the same towing rating as their goofy lookin 09 ram with a hemi, but now they're really mad that they're owned by FIAT(they did do good things for ferrari though so maybe dodge wont suck so much pole now?). GMs kinda in the ****ter too since they're owned by the govt, it's like paying tax on money that's going straight to them anyway, awesome right? They'll all learn, i mean ppl told me this video was staged. Morons
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
