I had a brain fart earlier, I was going to say splitfires too, but I couldn't think of the name. i had split fires in my 76 Chevy and didn't notice any difference. 40.00 for plugs, I sure thought I would have seen something other than an empty wallet.
__________________
92 F-150 flairside all stock 5.0 auto 2WD
93 F-250 4x4 flatbed 5.8 auto KnN, throttle body spacer, underdrive pulleys, flowmaster
73 Jeep CJ5 springover axles, reversed front shackles, 304, T-18, lockers front/rear, 4:29 gears, 33s
87 Toyota Tercel Tuner some engine mods exhaust
try all those supposed octane boosters you can buy at crappyzone and walmart. see if they actually do anything at all. if you got the money see just how much an auto tranny robs over a manual??????? just throwin out anything i can think of.
__________________
90 f250 4x4 5-speed 351w headman LT's 33x12.5 coopers CHEVROLET-Cheap Hardly Efficient Virually Runs On Luck Every Time
Not sure if anyone has said spark plugs yet...Standard,Platinum,Double Platinum,Iridium or the $25 a piece Pulstar Pulse Plug..Havnt sold a set of those yet!!!
I saw throttle body spacers, but no one mentioned the upper to lower intake spacer.
I have seen on other websites that some people have removed the engine coolant flow from the throttle body. I suppose it is to reduce the temperature on the air charge.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
I thought the purpose of the coolant hoses on the throttle body was supposed to help the truck warm up quicker in the winter and even keep the throttle body etc from icing up in colder climates. I don't know if it can help keep it cool when its hot or not. My thought is that it was designed to be that way, so I don't think disconnecting it is going to make the truck run better.
As far as spark plugs go. I don't see how any of the split fire type or bosch platinums with the multi spark tip are going to produce more power when everyone says their truck doesn't run as good with them. It would be interesting to see if any of them do make more power though.
__________________ 1995 F-150 XLT 2WD 5.0 AODE (4R70W) 3.55 LS
1965 Mustang 302 T5
PICTURES AND INFO IN GALLERY
I only saw the throttle body heater hose removal on the small car websites, not sure what the affect will end up.
I also didnt see the airfilter modifications other than CAI, like the difference between OEM paper filter and the K&N drop-in/Fram airhog(if it is still around).
__________________
Yeah, removing the coolant flow from the throttle body is pointless. It's not like the air is flowing through a mini radiator inside the throttle body. Not to mention, the throttle body is smack dab on top of the engine where it's gonna get hot anyway. The coolant would at least keep it down to no more than 195ºF, which the incoming air would help with also.
Alot of guys remove the TB hose because they start to leak or they just want to clean up stuff under the hood . If you don't live in a cold climate you don't need it , the TB should run cooler with out it but i don't now if it would help performance wise ??? Lew
I have unscientifically "tested" some of these things over the years swapping parts and trying these simple things to see if they make any difference at the SOTP dyno. Nothing to do with the TB has any effect on the truck motors, on a HO there are benefits to opening up the upper to accept a larger TB but that's because it works so much better at rpm and the HO intake is so much smaller than the truck setup. With the engine at operating temp even fairy large changes in ambient air temp have almost no effect at all on air temp inside the motor, there's just so much heat energy contained in that massive aluminum intake the incoming charge is instantly heated. The way the EEC-4 computer works also rules out benefits from higher octane fuel, MSD style ignitions and Hi tech spark plugs. The computer is set to a base ignition profile and all it can do is take out timing if detonation is sensed(on knock sensor equipped motors). Unlike the newer EEC systems it isn't programmed to constantly advance timing to the limit of detonation so you won't see any benefits from these things unless you manually advance the base timing more.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
I use the TB coolant lines are a way to bleed air out of the cooling system, other than that, they are another "$$$ problem" down the road.
__________________
89 F250 2x4 302/AOD 4.10 gears ,now on road.
89 Bronco2 with dead A4LD again
84 F250 4x4 300/np435 3.55 gears. The BLUE MULE shut down due to cab cancer(looking for good cab)
95 E350 bus conversion 460/E4od 4.10 the new toy!
85 Plymouth Caravelle 2.5L someday to get the hairdryer treatment(turbo)
93 explorer now just a woods buggy
i would like to see a cam swap (biggest one for speed density) and all of the other things you can do to get more air in with fuel injection different manifold injectors throttlebody air intake blah blah blah vs. a rpm airgap intake manifold with a cam that is reasonably larger than the speed density cam with more duration and lift than speed density can handle and a 750 holley if it's a 351 your doing testing to or a 650cfm holley if it's a 5.0
settle the debate, and don't be scared to wind the piss out of the motor with the huge cam in it to get that extra little bit of h/p hiding in the top end past 6k
__________________
89 F-150 leveling kit 33x12.5 BFG All-Terrains, Trick Flow Fast as Cast Heads, Comp Cams Gold Roller Rockers, Edelbrock RPM Air Gap Intake, Trick Fuel 750 Mechanical Secondary Carb, MSD E-Curve Distributor, Comp Cams 280hr Roller Cam, Comp Cams Roller Lifters, Comp Cams Valve Springs, Trick Flow Pushrods, DSS Main Girdle, ARP Bolts, Cometic Gaskets, Forged Pistons, 125 Shot of Nitrous, AOD, 3500 TCI Stall Converter, Lentech Street Terminator Valvebody, 4.56 Gears, Flowtech Headers, 2.5in Exhaust
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
