Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 12:52 AM
bigstakn bigstakn is offline
bigstakn is starting off with a positive reputation.
t19 to zf5 swap
I have a 1987 F350 2wd single cab long bed with the 6.9L and a t19. I just installed a zf5 out of a 1988 F250 2wd ext. cab long bed donor truck. The entire installation is completed but i have two questions. I have searched all over the forum and can't find the answer to these questions. I'm trying to use the drive shaft that was bolted to the t19 but the u-joint is not the right size, it is to small for the zf5's yoke. Is there a hybrid u-joint that will allow me to connect the t19 drive shaft to the zf5's rear yoke? The other question is will the speedo cable that was connected to the t19 bolt into the zf5 and work correctly?
  #2 (permalink)
Old 07-04-2009, 01:16 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Yup, I believe this is what you'll need 1330x1350 Universal Joint.
The best method would be to use the DS from the '88 with the 1350 U-Joints and replace the Yoke on the rear end.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #3 (permalink)
Old 07-04-2009, 09:46 AM
F250FarmBoy's Avatar
F250FarmBoy F250FarmBoy is offline
F250FarmBoy is starting off with a positive reputation.
Thats the exact same snag I had when i did my swap last september. I just went to napa and gave them the tranny's year (1990) and the driveshaft's year (1985) and they made me a u-joint with the right caps. Problem solved.
__________________
1985 F-350 6.9L 2x4
Flatbed, DRW, 4.10's, ZF-5 swap, buckets, push button GP's, 103k miles
1989 F-350 7.3L 4x4
Kingpin D.60, Srw, 4.10 l/s, push button GP's, ex-tree service truck, dumped utility bed for the bed off an '89 . Soon to get paint with the idea of yellow and black "boss 302" graphics....but it won't say "boss 302"
  #4 (permalink)
Old 07-05-2009, 06:20 PM
thanks so much guys I got it in and finished
  #5 (permalink)
Old 07-05-2009, 07:08 PM
Any pictures of the process, going to do a write up??
-Enjoy
fh : )_~
__________________
Tags
19 , 1987 , 2wd , 69 , 88 , diesel , duallyt19 , ford , gear , speedometer , swap , t19 , zf , zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
