Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 12:47 AM
1bddelx's Avatar
1bddelx 1bddelx is offline
1bddelx is starting off with a positive reputation.
1995 7.3 starts,dies then restarts
My neighbor is having an issue with his 7.3. He cranks it and it starts for 3 seconds or so, then dies. He then has to crank it 4 or 5 cycles for it to start and then it runs great. The truck has intake, chip, and down tube. What is wrong? Any help will be greatly appreciated. Thanks
__________________
2006 F-350 CrewCab Longbed 4x4 PSD
8" ProComp Lift With 37x13.50x18 Skins
Airbags
Banks Exhaust
Afe Drop In Filter
Tows A 36' 5er Lifted Also
  #2 (permalink)
Old 07-04-2009, 01:50 AM
k_conner k_conner is offline
k_conner is starting off with a positive reputation.
Is the CEL light on? If so...
Have him check the valve cover gasket/injector wiring harness on both sides. These are one peice gaskets that have connectors that run through them to the injectors. They are notorious for getting hot and melting, which shorts out the connection. They are cooled by oil so this mostly happens if you let the truck get low on oil.
Check all connections to the gasket and then pull the valve covers and check wiring underneath. It's best to actually pull the connectors apart. Sometimes they look fine on the outside but are completely melted on the inside.
__________________
97 PSD CrewCab 4x4
7.3 DI
Auto Trans
33.5 x 12.5 x 16.5 tires
CAT gutted, 3" DP
  #3 (permalink)
Old 07-04-2009, 09:14 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Adrenaline Junky
Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE.
Remove the chip and see if it runs OK.
What chip is installed?
A scanner would be very helpful.
__________________
JIM
  #4 (permalink)
Old 07-04-2009, 11:53 AM
1bddelx's Avatar
He already had this happen once. Thank you
__________________
Airbags
Banks Exhaust
Afe Drop In Filter
  #5 (permalink)
Old 07-04-2009, 11:54 AM
1bddelx's Avatar
Not sure what chip he has but I will see if he will pull it out for a test. Will a standard OBII scanner work fine?
__________________
Airbags
Banks Exhaust
Afe Drop In Filter
  #6 (permalink)
Old 07-04-2009, 12:40 PM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR is starting off with a positive reputation.
Ipr
Quote:
Check the wiring to the IPR and check to ensure that the flimsy not on it is not loose. Then check to ensure that the HPOP has oil in it almost to the top.
Check for codes.
On a WAG- Change the CPR.
Rocky
Tags
1999 , 73 , dies , diesel , f350 , ford , starts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
