Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 12:18 AM
Brett1989's Avatar
Brett1989 Brett1989 is offline
Brett1989 is starting off with a positive reputation.
302-forged vs hypereutectic pistons
In the 80's and early 90's mustangs with the 302's when did they switch to hyper. pistons? Also, which pistons would stand up to NOS the best and how big of a shot could be used without blowing it up?
Brett
__________________
'91 Ford Ranger std. cab 5-speed OD 2.3l
  #2 (permalink)
Old 07-04-2009, 04:25 AM
Dirt racer's Avatar
Dirt racer Dirt racer is offline
Dirt racer is starting off with a positive reputation.
Forged is the best, not sure about what year on any Hyp. pistons.
  #3 (permalink)
Old 07-04-2009, 06:30 AM
lew52's Avatar
lew52 lew52 is online now
lew52 is gaining momentum as a positive member of FTE.
I think they switched to the hyper pistons in 93 on the HO.. The forged are better for NOS...Lew
  #4 (permalink)
Old 07-04-2009, 12:41 PM
Freaksh0w's Avatar
Freaksh0w Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
Forged pistons, like said above, would be better for NOS.
__________________
1986 F-150 5.0 EFI XLT Lariat 4x4
NP435/NP208/9" 3.50
"Custom Exhaust" and leaf spring overloads
31x10.50 15" Nothing special, but it's a damn good truck.
  #5 (permalink)
Old 07-04-2009, 12:56 PM
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
yeah like lew said, in 93 they switched to hypers. i think 88-92 in the ho motor was forged. Forged will stand up alot longer to NOS.
__________________
  #6 (permalink)
Old 07-04-2009, 01:01 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
On the 5.0 motor the rod bolts are the weak link for high rpm and power adder apps, but that said the stock rotating assembly seems to reliable up to around the 400hp range.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #7 (permalink)
Old 07-04-2009, 02:24 PM
Freaksh0w's Avatar
I think it sucks the weakest link in most engines are the rods.
I had a 490-510 horsepower (crank) highly modified twin turbo (upgraded 15G turbos) Stealth R/T TT. Ross forged pistons. Aftermarket forged steel crank (came with a cast iron crank).
Stupid part on my part was the stock rods I left in there. Spun a bearing 3 times, threw a rod through two blocks. Was a few years back, I learned a lesson there. You can have the best crank and pistons in the world, but the rods are the weakest link if you aren't careful.
__________________
NP435/NP208/9" 3.50
  #8 (permalink)
Old 07-04-2009, 03:14 PM
lew52's Avatar
Quote:
..Are the rods ok or is it just the bolts ?? I guess a set of ARP rod bolts would be a good up grade... Lew
  #9 (permalink)
Old 07-04-2009, 04:34 PM
Conanski's Avatar
1990 Ford F-150
Yes ARP bolts are the fix.. though by the time you buy the bolts, have the old ones pressed out.. new ones pressed in.. and the rods true'd again, you could have bought an aftermarket set with ARP fasteners installed.
__________________
Paul O
  #10 (permalink)
Old 07-04-2009, 04:38 PM
lew52's Avatar
Thanks thats good to know.... Lew
  #11 (permalink)
Old 07-04-2009, 04:49 PM
Freaksh0w's Avatar
So, somewhat off subject, but what do you think the limit is for my stock '86 EFI 302? I do know it pulls to 5000RPM and can pull farther, but I never take it passed there. Is 5000RPM too high? Just curious, I know it doesn't mean much.
I know 5.0's are great revving motors with the 3" stroke, so can the stock rods and bolts take 5k RPM pretty easy?
__________________
NP435/NP208/9" 3.50
  #12 (permalink)
Old 07-04-2009, 07:18 PM
Conanski's Avatar
1990 Ford F-150
Yeah 5k is no problem.... 6k+ is when things get hairy. I'll add that with an all stock '86 truck motor you're really just making noise reving it that high, the whole powerband is below 4000rpm.
__________________
Paul O
  #13 (permalink)
Old 07-04-2009, 07:30 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
1994 Ford Mustang
My Garage
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
92 was the year that they made the switch. Some of the 92 302s have forged pistons and others are hyper.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
http://mistercmk.com/images/sig.jpg
Quote:
Originally Posted by tcbofade
I have no brain
  #14 (permalink)
Old 07-05-2009, 10:34 AM
Freaksh0w's Avatar
According to specs and a few other people on the board, that is true. I'll make a vid, though, it pulls harder up to 5k RPM, and would pull farther, but I'm 'scared'. Off subject again, but when I used to use Castrol GTX 10W-30, 5k would die off in power, then I tried GTX 10W-40 for one oil change, and it died in power around 4700RPM (yes, I watch closely). I went back to 10W-30... but now all year I've been running Rotella-T Synthetic 5W-40, and I don't notice a difference except that 5K RPM is not a 'wall' anymore. It wants to go on. I'm sure the engine is stock, though, but I'll have to take a picture/vid for you guys showing it pulling to 5K in 3rd (NP435) doing over 65MPH. It really winds out.
__________________
NP435/NP208/9" 3.50
  #15 (permalink)
Old 07-05-2009, 03:04 PM
Freaksh0w's Avatar
Just one of my 5 vids or so. Just showing it goes to 5k easy.
Yes, I'm spinning all through 2nd gear. I just held it at 5K RPM.
__________________
NP435/NP208/9" 3.50
Tags
23 , 302 , 50 , 50l , cast , ford , fords , forged , hyper , hypereutectic , pistons , put , sbf , stock , year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
