Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 07-05-2009, 05:16 PM
Freaksh0w's Avatar
Freaksh0w Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
Can't edit. Might as well post the rest of the stupid vids. I don't think it dies at 4000RPM though.. I kick it at 4 grand in this video:
Here's the rest. Crappy, I know.
__________________
1986 F-150 5.0 EFI XLT Lariat 4x4
NP435/NP208/9" 3.50
"Custom Exhaust" and leaf spring overloads
31x10.50 15" Nothing special, but it's a damn good truck.
  #17 (permalink)
Old 07-05-2009, 05:47 PM
lew52's Avatar
lew52 lew52 is online now
lew52 is gaining momentum as a positive member of FTE.
I don't think that kind of RPM is doing you any good , but if you build the motor then 6K is no problem for a 302 & will get there quick with the right gears... Lew
  #18 (permalink)
Old 07-05-2009, 06:22 PM
Freaksh0w's Avatar
Right. But is it 'dangerous' for the engine in its stock form? And I'd love to have some 4.11's for my 9".
__________________
NP435/NP208/9" 3.50
  #19 (permalink)
Old 07-05-2009, 09:57 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
1994 Ford F-150
6CylBill has a good reputation on FTE. 6CylBill has a good reputation on FTE.
Quote:
Originally Posted by Freaksh0w View Post
Just one of my 5 vids or so. Just showing it goes to 5k easy.
Yes, I'm spinning all through 2nd gear. I just held it at 5K RPM.
Wow, that is impressive! And think, a few internal mods and you can be revving to six or seven grand and be making power.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #20 (permalink)
Old 07-05-2009, 10:29 PM
Freaksh0w's Avatar
Yeah, I want to do some things to it, but dunno when I'll ever be able to. I'm thinking GT40 heads, headers, true duals, and around a .480-.500 lift cam with around 212 duration at .050". Not too much duration, I want some mid-low range power.
But, with my luck, someone will total my truck before I ever get to play with mods.
__________________
NP435/NP208/9" 3.50
  #21 (permalink)
Old 07-05-2009, 10:50 PM
6CylBill's Avatar
1994 Ford F-150
Don't talk like that Homie. It's never good to talk like that.
302's have a lot of aftermarket. You could really get some impressive power out of that thing. You're not from 200 horse already. A little money and you can be seeing 300 horse. True duals seem to really open up V8's, assuming you have headers. I like glass packs for V8's; I don't care what anyone says, a glass pack still flows better than a baffled muffler. Thrush glass packs have a 2'' inner core. Cherry Bomb's are supposed to be more narrow, that's why I'll only run Thrush.
Have you looked into adding OD to your tranny? Add OD and you can add 4.10's to your arsenal without hurting your fuel mileage too much.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #22 (permalink)
Old 07-05-2009, 11:03 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
If you ask me that motor already has a cam in it.. stock flat tappet 5.0 truck motor does not like to rev like that one... assuming the tach can be considered accurate.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #23 (permalink)
Old 07-05-2009, 11:28 PM
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
i heard 302s make good boat anchors....
__________________
  #24 (permalink)
Old 07-05-2009, 11:40 PM
6CylBill's Avatar
1994 Ford F-150
Quote:
That would be the 305 and 318 you're talking about.
Now those are two V8's I'll go head to head against.
I know without a doubt a 300 will out work a 305. Don't know about the 318. I think the 300 would simply be more efficient than the 318.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #25 (permalink)
Old 07-05-2009, 11:43 PM
HA! a 318 will walk away from a 302 like its standing still. 305s are a whole another story..
__________________
  #26 (permalink)
Old 07-06-2009, 12:00 AM
6CylBill's Avatar
1994 Ford F-150
I don't know about that. Carb to carb, a 300 makes more power than a 318 in both horse and torque. I can't see a 318 making more than 180 horse with EFI.
Bah, let's just get a big get-together in the sticks. You know any Dodge guys with 318 powered trucks? We'll all bring some foodz and drinkz and see what's what!
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #27 (permalink)
Old 07-06-2009, 12:08 AM
lets not talk about 80s carb motors, since all across the board from every company they were terds. the efi 318 magnum however, made 230hp and 300ft lbs. which would lead me to believe it would be a fair fight for a 351, if dodge's transmissions werent so power robbing.
__________________
  #28 (permalink)
Old 07-06-2009, 12:10 AM
6CylBill's Avatar
1994 Ford F-150
Holy crap, really? How did the 318 go from 130 horse to 230?
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #29 (permalink)
Old 07-06-2009, 12:15 AM
look up 318 magnum, in 92 they redid the whole motor with new cylinder heads, and of course efi.
The 80s motors all were really crappy from dodge, with the exception of the cummins, because this was when chrysler was just coming out of the brink of bankruptcy, so they just put everything together as cheaply as possible which made for really unimpressive engine packages.
__________________
  #30 (permalink)
Old 07-06-2009, 04:50 AM
lew52's Avatar
I had a 73 340 duster that was rated at 240 HP , but it was a dog even in a duster . Hows the 351 build going ??? Or did you use it for an anchor ??? Lew
Tags
23 , 302 , 50 , 50l , cast , ford , fords , forged , hyper , hypereutectic , pistons , put , sbf , stock , year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
