Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-04-2009, 12:08 AM
stevenbhenry stevenbhenry is offline
stevenbhenry is starting off with a positive reputation.
04 Explorer alignment specs
2004 Explorer Limited 6cyl 4X4
With about 60k miles I replaced my tires and had a wheel alignment. The alignment printout listed the vehicle as a 4X2 and showed the factory specs. When I questioned the service rep he said the specs for the 4X4 and 4X2 are the same. Does anyone know if this is right? I tried to find specs on-line but don't want to have to pay a fee to get them.
The left front had a normal negative camber -0.3 but the right front had a negative camber right on the border line -1.6. This put the cross camber out of spec at 1.4. The mechanic clalims this won't wear tires or cause handiling issues, and it would take him 3 hours labor to put a camber kit in to correct it if I wanted to bring it within specs.
The tires didn't show any unusual wear, all four tires were getting low on tread.
Is this anything to worry about?
  #2 (permalink)
Old 07-08-2009, 11:10 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) is gaining momentum as a positive member of FTE.
the allignment specs are a rough idea of where you should be. the tell tale info is how they look after 20k miles. the wear tells you to move to the other end of the spec, or leave it alone. it sounds like your o.k. if you had even wear at 60k miles. Apparently your mechanic knows his stuff, thats nice to know.
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 190,000 miles
2002 Explorer 4 x 4 4.0 XLT - 120,000 miles
Tags
2000 , 2003 , 2005 , 4x4 , 91 , alignment , alinement , camber , explorer , ford , mountaineer , rear , specs , spects , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
