Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 07-06-2009, 09:44 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
I could not say exactly, however diesel hangs around pretty long and I think it would be noticable for weeks, though I don't know for sure.
The closer to the last run the eaiser it is to see, however just turning the motor over and having fuel pumped through the injectors is all that would be needed.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #17 (permalink)
Old 07-06-2009, 01:19 PM
Hotairjunkie's Avatar
Hotairjunkie Hotairjunkie is offline
Hotairjunkie is starting off with a positive reputation.
Ok, I just pulled the front two injectors on the driver's side of the engine after running the truck for about 1minute to move it in the driveway. Both are wet. Not only the tip is wet, but the entire injector pretty much from the threads down. So, I'll be ordering a new set of injectors today, unless someone here tells me different! Thanks!
  #18 (permalink)
Old 07-06-2009, 11:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Given the miles on them, I bet most of them are leaking.
The internals wear, and when the injector should be popping closed after injecting the fuel, it don't seal.
So the fuel continues to leak into the cylinder.
To much fuel and at the wrong time is the result.
Stop to think a minute.
My guess is you have a 4.10 axle, so every mile you drive in fifth gear at 60 MPH that injector is firing 1025 times.
186,550,000 times in 182,000 miles if they were all driven at 60 MPH and all in fifth gear with no idle time.
Add in idle time and driving time below fifth gear, those injectors have probably popped well over 500 million times.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #19 (permalink)
Old 07-11-2009, 08:51 PM
Just a quick update. I just installed a new Autometer EGT gauge. I installed the pyro in the driver's side exhaust manifold, drilling in from the underside, behind the backmost cylinder, right before the downward bend. I just took it for a quick spin. After letting it get up to temp, pulling a slight (2% max) incline, I saw EGTs of 1250 - 1300 at 60 mph, 2700 rpm, in 4th gear (5 speed manual trans).
I have new injectors ordered, and hope to get them next week. Hopefully, this will give me more complete combustion, and lower the EGTs. However, I am more and more convinced that the exhaust restrictions created by a combination of a stock 2.5" pipe, and a very long run given the extended wheelbase of this truck, are contributing significantly to the high EGTs.
Anyone want to chime in on this?
  #20 (permalink)
Old 07-11-2009, 09:26 PM
harleyjohn45's Avatar
harleyjohn45 harleyjohn45 is offline
harleyjohn45 is starting off with a positive reputation.
I thought i was running hot, 1250-1300 and the truck is still running.
Hopefully the new injectors will cure this problem, If its still running 1200, you need to back the fuel off. These trucks were always slow and now 182,000 miles it is still slow. Nothing short of a turbo charger will give you much power, and with a turbo charger it will never be a speed demon. However it will run smoother and what power you have will be easy power.
__________________
1991 7.3 liter non-turbo F-350 superduty/12' dump bed.
  #21 (permalink)
Old 07-11-2009, 09:52 PM
1986 Ford F-250
Small pipe = small hole for heat to exit
Big pipe = big hole for heat to exit
The small pipe size Ford used did not help any aspect of the engine.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #22 (permalink)
Old 07-16-2009, 02:25 AM
Injectors arrived yesterday. I installed them today. Surprisingly, it took me less than an hour to install all 8. I nicked one o-ring and had a return cap leak, but found that pretty quickly. The excess fuel in the valley where the glow plug sits revealed an air leak around the GP. Tightening that up took care of it.
On test drive, I did notice that I was able to get up to 65-70 a bit faster and hold speed in 5th, whereas before, to hold 60 - 65 required 4th gear. I didn't notice any big improvement in accelleration, but being able to maintain my speed on a slight grade was sure nice.
She still has a bit of smoke, but not as much as before. EGT was about the same, 1250 - 1300, but settled down a bit in 5th once I was up to speed.
I think I'm getting about all that I can out of this old beast now, sans turbo. I'll keep my eyes out for a used turbo and we'll see what happens.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
